Brake pad cross reference?
My Cousin just bought a 05 gt. He needs pads, what are the part numbers, and or cross reference to a Audi or Vw pad? Tia. --Rob
you can only cross ref the rears pads and rear rotors. I used audi a8 w12.The audi has 3 (different size rear rotors) I had work done at my local vw dealership.
Originally Posted by BentleyF
(Post 4078230)
Originally Posted by awdbiturbo1
(Post 4078202)
Rear pads; 3W0698451B Front pads: 3W0698151G |
Alternate Brake Pad supplier
You might want to investigate Carbotech (Concord, NC), as they have pad listings for both Bentley and Audi models:
www dot ctbrakes dot com They have a toll free number, and they can also put their compound(s) on your old pads. |
this is interesting - i have steel rotors - still very good but want to be prepared for change...
are there any replacements from audi/vw or 3rd pty with good quality but no bentley-logo tax? |
I found this previous thread which might be helpful
https://www.6speedonline.com/forums/...iy-thread.html |
hi Guys!
in the referenced links there are xref for break pads but is 2010 post. veeeryyy old. now - what brake pads you use (3rd pty vendor - without bentley tax) of good quality for fair price 2010 proposal: W12 oil filter element : Mann Evotop HU 932/6x W12 Engine oil : Fully Synthetic 0W-40 (i.e. Mobil1) Front Brake Pads : Delphi # LP 1002 or Ferodo # FDB 1001 or Mintex # MDB 1746 (L=195mm x H=74mm x T=20mm used on Audi RS4 2000-2001 and Mercedes-Benz C43 AMG 1997-2001) Rear Brake Pads : Ferodo # FDB 1672 (L=139.6mm x H=67.8mm x T=17mm used on BMW M5 E60/E61 and BMW M6 E64) Front Brake Rotors : 15.9" x 1.4" Alcon Rear Brake Rotors : 13.2" x 0.9" Alcon (from Audi RS6) but eg mintex 1746 is continental (not gt) i would like to get fresh proposals pls |
Originally Posted by sazam
(Post 4923363)
hi Guys!
in the referenced links there are xref for break pads but is 2010 post. veeeryyy old. now - what brake pads you use (3rd pty vendor - without bentley tax) of good quality for fair price 2010 proposal: W12 oil filter element : Mann Evotop HU 932/6x W12 Engine oil : Fully Synthetic 0W-40 (i.e. Mobil1) Front Brake Pads : Delphi # LP 1002 or Ferodo # FDB 1001 or Mintex # MDB 1746 (L=195mm x H=74mm x T=20mm used on Audi RS4 2000-2001 and Mercedes-Benz C43 AMG 1997-2001) Rear Brake Pads : Ferodo # FDB 1672 (L=139.6mm x H=67.8mm x T=17mm used on BMW M5 E60/E61 and BMW M6 E64) Front Brake Rotors : 15.9" x 1.4" Alcon Rear Brake Rotors : 13.2" x 0.9" Alcon (from Audi RS6) but eg mintex 1746 is continental (not gt) i would like to get fresh proposals pls Here is a little fresher info: Changing Rear Brake Pads Conti GT - 6SpeedOnline - Porsche Forum and Luxury Car Resource I had changed both front and rear pads on my 05 GT with aftermarket brands. Given Bentley's relationship with VAG and so many common systems across models, the aftermarket has done a lot of the crossover brake parts for you. In the US we have some good online parts suppliers such as Rockauto, and Amazon often carries the same products with a P/N. Hope this helps |
For my GT 2005 i purchased the following, will see if it is good fit:
front: fedoro fdb1001 rear: fedoro fdb1655 |
