2005 CGT Air Pressure monitor Problem
Old 05-29-2014, 08:44 PM
neishadave's Avatar
neishadave is on a distinguished road
Hello again ;-)
My CGT was parked in the garage and I forgot to plug in the Ctech. Long story short, the battery died. I was able to start it with the Aux bat. Now the info center on top of the steering column has the tire pressure light with a line through it illuminated. I tried resetting the pressure and that info center on the Nav screen shows 4 hour glasses and will not show the true tire pressure numbers. I checked all the tires manually and they're all 100% 46psi front/43 rear with no leaks. Has anyone experienced this before? If so, can you help with the remedy. Never had any issues prior to this with the sensors. I also doubt all 4 sensor batteries died on same day. Thank you for you help.
Old 05-30-2014, 05:50 AM
neishadave's Avatar
Originally Posted by Bentley tech NY
Have you ever had the TPMS module replaced? How long have you owned this car? I have replaced a lot of those modules on the early cars. The module is located behind the drivers side interior quarter panel. best to scan it and see what faults you have
I've owned the car for 6 months, it was purchased from a good friend whom had it from the start. Never any issues. I don't think the module has ever been replaced. Again, this just occurred after the battery discharged. Can you recommend a scanner that works best for this car? I really appreciate your help.
Don't worry I will post more than two more questions..lol.
Old 05-30-2014, 08:53 AM
neishadave's Avatar
Best diagnostic software and cable is from Ross-tech.com. Aka VAG-COM. They have lots of information great product support and it worth every dollar.
Thanks again, I appreciate your help and time.
Dave
04-28-2022 12:38 AM
2lflat4
11-18-2019 05:05 PM
ECS Tuning - VW
08-27-2015 08:30 AM
The Oss
08-24-2015 08:19 PM
pwdrhound
08-20-2015 05:54 AM
Quick Reply: 2005 CGT Air Pressure monitor Problem
