Replacing Battery in Continental GT key fob
Hi All
The warning light on my dash said low battery key so I replaced the battery(C2032) but it still says battery low
Has anyone else had this issue in a 2009 GT
I just got the same message. Have owned the 2009 GT for just under two years. Last time I replaced the key fob battery it worked fine. This time I still get the battery low warning. Replaced the new battery with another new battery which I checked on a volt meter.
It reads 3.4 volts. but I am still getting the key battery low warning each time, but the car starts fine???????
Must be some way to reset it.
Kim
Kim
Some times my car will flash "key not found" even after it's been started. It goes off and all is well I did replace my fob battery a couple years ago may be time to replace it again. I change my Motorcycle fob batteries out every other year.
When my battery was low I got the key not found warning and some times I had to insert the key to start the car. I replaced the fob battery and car starts fine but still got the battery low warning.
I went out and got a new battery and checked it with my meter. It showed a solid 3.45 volts. Car starts fine but I still have the warning message and it never goes away.
Wonder if there is some way to reset it? Maybe I should unhook both car batteries for a few minutes? Any ideas.
Kim
Kim
Kim
Kim
I replaced the key battery and still had the message. I reset the service indicator and the key message cleared. I guess that when the dealers do your annual service that the replace the key battery and reset the service indicator.
04-28-2022 12:38 AM
Armytrix_F1_Exhaust
07-07-2019 11:31 PM
cnebrask
09-17-2015 09:19 AM
I'mAllIn
09-11-2015 06:38 AM
