2005 Bentley GT - Door Chime Stopped Working, Help Please
Was wondering if anyone could help me. I have a 2005 Bentley GT. For the past month the door chime (when the doors are left open, or if I accidentally leave the headlights when I turned the car off) started sounding like it was blown out. It would buzz, but not the normal chirping sound. Then yesterday the door buzzer completely stopped working. When I leave the lights on, or if the door is open there is no buzzer to let me know. I also realized that my blinkers to not “buzz/beep/click” when the blinker is on (The lights work ok, just no noise). Anyone know where the door chime/buzzer is located and how to access it? Any information would be greatly appreciated.
Thank you very much. Just curious what the DIP unit is or where I can locate it. Thank you Bentleytech
Drivers Information Panel, there are a total of three fuses located in the dashboard, driver seat kick well, use a flashlite and look under steering wheel, either a release handle for panel to access fuses or just a pull down, just check all fuses if you are not sure which are the ones, good luck
2lflat4
11-18-2019 05:05 PM
stevenrmusic
Bentley
17
11-12-2015 05:53 PM
