2007 Bentley GT Steering wheel doesn't go up or down.
Old Sep 18, 2020 | 09:19 AM
  #31
crusher's Avatar
5 Year Member
crusher is infamous around these parts
just a note as i know this is an old thread, i did this on mine without airbag or steering wheel removal by just removoing the bottom cowl which was as described fastened with two star screws and one allen key underneath...
had to rotate the wheel to get to the side screws but no problem and came apart pretty easily.
to be honest i dont think you could remove the top part so if that bwas needed as johnny says you would need to remove airbag and wheel.good luck all
Old Sep 18, 2020 | 05:45 PM
  #32
gordon9898's Avatar
gordon9898 is a jewel in the roughgordon9898 is a jewel in the roughgordon9898 is a jewel in the roughgordon9898 is a jewel in the rough
Originally Posted by Eversleyhall
Hi Chaps,
Apologies for the silence on this topic, I thought i should provide closure on this, and confirm that thanks to you all, i have this sorted - however not in any of the technical ways you have suggested.
Having deliberated over how brave i am in removing the airbag, it occurred to me that all i would be doing once i had removed everything is freeing up a jammed drive cog.
Armed with my BF&I logic, I pressed the joystick up and down whilst firmly slapping the underside of the steering column cowling where i guessed the motor would be. And there we have it. After a few slaps, it started working, and has continued to do so.
Again, many thanks for your help - it is now booked it to get both electronic park brake motors replaced, ah the joys
well done!
Old Feb 19, 2024 | 10:39 AM
  #33
Filippo79's Avatar
Filippo79 is infamous around these parts
old thread but just to say i had the same problem. Without removing anything I just gave a couple of "strong" knocks on the area and all worked again. Assume it was slightly clogged.
thanks for the advise
Old Feb 25, 2024 | 04:23 PM
  #34
Randy V's Avatar
5 Year Member
Randy V is infamous around these parts
Good to know!
Old Mar 28, 2024 | 12:09 AM
  #35
AJ1's Avatar
AJ1
5 Year Member
AJ1 is infamous around these parts
Long term owner of mine and this has happened maybe a handful of times and I’ve never needed to remove the steering wheel to fix it. I’ve always moved the column in and out to the extremities and quickly pushed the up/down at each end while hitting the lower steering cowling hard. Making sure engine is running and hey presto - every time.
r6vr6
Feb 18, 2018 11:23 AM
977ttblue
Mar 4, 2016 10:18 AM
REKX
Mar 1, 2016 08:32 PM
Sejzilla
Feb 26, 2016 01:53 PM
