-   Bentley (https://www.6speedonline.com/forums/bentley-42/)
-   -   Hood won't open! Jammed latch mechanism? (https://www.6speedonline.com/forums/bentley/388456-hood-wont-open-jammed-latch-mechanism.html)
turbo_secret Apr 8, 2016 11:45 PM
Driver side latch mechanism wont release! The passenger side does. The cable is not ripped. Any ideas? The only way i can think of releasing it is by cutting the hood grill and cutting the hinge off the hood but i really dont want to do that :(
ULSTRUP Apr 9, 2016 09:32 AM
as far as I know there is no ''driver'' ''passenger'' hood release mechanism but a central one operated from the driver side.anyway the mechanism is very simple and operated by a cable, thus the problem must come from the cable itself.before ''disfiguring '':eek: your car you might try to take off the driver lower left side panel (or right if you're in the UK) and try to reach the cable and find out what is happening there.
joc44 Apr 9, 2016 10:21 AM
https://cimg5.ibsrv.net/gimg/www.6sp...674323c348.png
turbo, i see 3 latch's but not to sure right now
how they work !
have you pulled the handle as someone pushes down no the nose cone
above the latch.
turbo_secret Apr 10, 2016 10:02 AM
I tried just about everything! It just looks like one of the latches just got jammed and wont release
:( i hear a click noise coming from the latch whenever i pull the handle. And yea we tried to push and pull on it while someone was pulling the release handle. There is no way getting to the latch because everything is so packed on these cars. I think i will have to cut the grill :(
turbo_secret Apr 13, 2016 12:39 AM
4 Attachment(s)
Had to cut the driver side grill with a grinder and then with a sawzall i cut the hood hinge off. For some reason the driver side hinge got stuck and wouldnt release.
ULSTRUP Apr 13, 2016 11:21 PM
ouch! I feel sorry for you.
krall Apr 19, 2016 07:31 AM
That. Sucks.
What a pain! Can you tell what caused it to jam?
REDNOSEGT Apr 20, 2016 05:16 PM
wow
what caused it to jam x 2
lack of lubrication? cable fail? cable stretch?
im going to soak mine with anti rust spray right now!
joc44 May 29, 2016 02:12 AM
FOR NEXT TIME.
https://cimg6.ibsrv.net/gimg/www.6sp...646a8d6ab6.jpg
https://cimg7.ibsrv.net/gimg/www.6sp...d0d1066a94.jpg
ExSF May 29, 2016 02:29 AM
Special tool. A bent plainblade screwdriver then.
Thanks for the info' joc44.
Les.
