2009 Bentley GT headlight parking light bulb help
Old Apr 14, 2018 | 08:11 PM
Cgt2017's Avatar
Cgt2017 is infamous around these parts
Hi, so I attempted to replace parking light bulb (yellowish color w5w bulb at the lower portion of headlight). I was not able to remove the bulb - do you have to rotate it a certain way to remove? Also now it stopped working and warning light comes up. Please help, not sure what to do next. (keep going to change this bulb, change the fuse?...) Thank you.
Old Apr 15, 2018 | 03:19 AM
ExSF's Avatar
ExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to all
I changed mine for LED W5W type bulbs.
The old ones just pull out, but they were well and truly stuck in there. It took me ages.
I eventually managed to spray a bit of WD40 on them and used a very fine screwdriver to prise them out. It's a very fiddly job.
AudiThunder
Bentley
Nov 30, 2016 09:59 AM
bansasn
Cayenne 955/957
May 20, 2012 08:48 PM
BentleyF
Bentley
Mar 19, 2012 05:11 AM
VINTAGEFEFE
Maserati
Mar 1, 2011 01:40 AM
bluetosman
Jan 30, 2007 02:14 PM
