Bentley P0243
Old 09-14-2018, 04:22 PM
executivecollat's Avatar
executivecollat is an unknown quantity at this point
Bentley P0243
Hi I have a 05 Bentley continental Gt right at 91k miles and recently i have multiple misfire codes (which its time for servicing) , but could the spark plugs be causing P0243 for wastegate solenoid? The car runs perfect other than the skip from the misfire occasionally.
Old 09-14-2018, 05:30 PM
1eapplebaum's Avatar
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
P0243 indicates an electronic anomaly of the vacuum solenoid. Should n75 fail, engine out repair. The internal ground fault referenced by this trouble code is the precursor to the component failure. The current fault not resulting in performance change is because the ECU is seeing a random issue.
Would be interested to know the misfire codes. Misfires could support vacuum leak?
Old 09-18-2018, 02:27 PM
That's exactly what it is, I just got a diagnostic test from a shop and its the vacuum lines on the tranny.. FML
saads
Bentley
03-19-2022 04:54 AM
samy999
Bentley
30
10-04-2018 12:00 PM
Hawkinz69
Bentley
34
06-09-2018 10:27 AM
MisterBojangles
Bentley
02-04-2018 09:14 AM
Quick Reply: Bentley P0243
