Coolant Smell
Hey All,
Getting a faint coolant smell after spirited driving. No lights/errors, just a faint smell. No leaks under the car either. Don't appear to be loosing coolant, or at least not so much/fast it's impacting the level. Oil and coolant appear normal, no milkshake or cloudiness. Any 'usual suspects' to look out for? |
pinhole leak or crack on radiator and coolant is burned off as it leaks...pressure test segments of the cooling system...
Thanks much, will try and see if I can locate it using a 'rented' pressure tester.
Find it?
Thanks for checking in and apologies for the late reply as I've had a few other diy items ahead of this one.
Hope to tackle this next weekend along with a brake job. |
