07 continetial gt 14,000 miles cooling fan issue!
Hello ,
i have a cooling fan fault want to replace both fans
I was told that the vw phanton fan motors are exact matches that can be bought separately, however the
replacement from Bentley comes with the shroud and fans and is thousands of dollars !! The vw fans are about $500 each . Can someone please confirm this part will work ??
Cooling fans
Thanks for the reply... the engine light is on and both fans are now not coming on ... Dealer diagnosed and
determined I needed to replace the entire fan assembly @ $4000 car is running perfect .. but I haven’t driven it for long periods because I don’t want to over heat it ... the car was taken to a local Bentley mechanic and he needs to remove the nose of the car before he can get fully diagnose.. he did mention a bad sensor or power supply issue! Paying him $800
to get some answers ..
