More drain maintenance ( part 2)
Following on from maintaining the loom killer scuttle drain there a few more to attend to .
Fuel filler - Bentley could not make a smaller more block able one . I have seen mine blocked a few times with just dust , forms a kinda mud .Thankfully the surrounding rubber can be plunged with your finger tip . Accidental water ingress into the filler neck while refuelling is not funny . Rear spoiler discreetly packs away and blends into the rear glass base .Its actually attached to the front edge of the boot / trunk lid . Two drains are located just behind the hinge mechanism.They run via tubing through the lid and exit water at the lower edge .This water just then runs down the bumper from water under the lid . If blocked or the internal pipage comes apart the trunk can fill up as well as soak the contents of the boot / trunk liner . The liner has the spoiler control and motor wires in , to be at best corroded ,worst destroyed, the bottom of the trunk has many water sensitive components like your air suspension air pump waiting to be destroyed. Theres obviously your batteries a bit higher in the lateral compartment s + crucially many ECU ,s not particularly partial to damp seeping up from the lake in the spare wheel well you are carrying around . Air Con evap pan . Humidity drips onto this pan situated unde the cabin side of the HVAC unit .The water should drain out into the trans tunnel via two rubber elbows . If these block or the orifices ( one each side ) the water level can rise and spill over the pan wetting the carpet and water runs as well as air through the ducting to the rear passenger compartment. Damp carpets no real biggie apart from misting up and foolish odours . The biggie is wetting any sensitive stuff in the centre console = corrosion. But and it’s a big BUT in the passenger foot well there’s another fuse box , actually a relay box with a poorly fitting lid . In there lives the Keyless Entry Exit Starting System , ( KESSY ) relays - Get that baby wet is serious hassle . Apart from the obvious starting hassle , if the starter motor won’t shut off it and burns out this necessitates the engine out to replace . Its an easy job to pull the elbow vertically and rod out the drain hole . https://cimg2.ibsrv.net/gimg/www.6sp...85bd4ead4.jpeg Two arguably THE most important tools for a GT Continental Strimmer cord and a pipe cleaner . https://cimg9.ibsrv.net/gimg/www.6sp...9865c1662.jpeg The worlds smallest fuel drain hole , right in the bottom corner .Use the cord or compressed air to clear . https://cimg6.ibsrv.net/gimg/www.6sp...3831d0620.jpeg 1970,s Ferrari with a nice size fuel filler drain highlighted in blue .Never clogged https://cimg0.ibsrv.net/gimg/www.6sp...44160fa2d.jpeg Two exits , one each side under the boot / trunk lid edge . Water should run out and flow over the bumper . https://cimg2.ibsrv.net/gimg/www.6sp...48e16c2d2.jpeg The drains are at the rear of the hinge mechanism.Raise it to access. https://cimg5.ibsrv.net/gimg/www.6sp...1ebf71a87.jpeg Spoiler drains from the top . https://cimg7.ibsrv.net/gimg/www.6sp...a210a15e6.jpeg Your aircon evaporate drain pan runs out through two rubber elbows into the trans tunnel . https://cimg6.ibsrv.net/gimg/www.6sp...644b1066e.jpeg Pull back the carpet to expose them . https://cimg7.ibsrv.net/gimg/www.6sp...b419bc58e.jpeg Pull off the vertical part off and insert the pipe cleaner to rod out . The AC condensate fills a pan under the HVAC unit . https://cimg9.ibsrv.net/gimg/www.6sp...f7e2025da.jpeg Full none draining AC pan eventually end up with water sloshing sound and spitting out of theses rear sea vents . https://cimg0.ibsrv.net/gimg/www.6sp...d0eaba695.jpeg Sensitive switches and pcb,s to corrode from spillages if the AC drain pan can’t drain , |
Originally Posted by John Fiammetta
(Post 4779425)
Where did you get the plastic piece that's stiff enough to do the spoiler drain?
Miine must be blocked, my installer told me there was a couple of inches of water in the spare wheel well that they drained out. Is that from the spoiler? |
Good writeup again John.
On the aircon tubes, were the elbows clogged? Both directions? Or did you just need to rod on the vertical as the tube enters the trans tunnel? I've already done the others early (and still do often), but this one is on my "new" list. Thanks Steve |
Originally Posted by British
(Post 4783252)
Miine must be blocked, my installer told me there was a couple of inches of water in the spare wheel well that they drained out. Is that from the spoiler? The trim from the inside of the trunk lid is removed easily .A few screws and then pull the clips . Sometimes the pipes / tubes can disconnect as well so well worth a look to eliminate. |
Originally Posted by BWings
(Post 4783397)
(Post 4783816)
You just shove a pipe cleaner vertical to clear any blockage after pulling the elbow down .
https://cimg1.ibsrv.net/gimg/www.6sp...dc607d00e.jpeg https://cimg3.ibsrv.net/gimg/www.6sp...f09bb934d.jpeg Can someone just take a zoomed out picture of this area so I can get a clearer understanding where exactly it is located? To me it looks like the back of the front seat. It doesn’t have to have the carpet pulled back. Just the area. Thanks |
Transmission tunnel I think...
https://cimg7.ibsrv.net/gimg/www.6sp...e705af063.jpeg
Here and the other side , pull down the carpet . |
(Post 4830936)
Here and the other side , pull down the carpet . Awwwww, thanks John... I was just there last week running my microphone wire!!! |
Cheers mate will do all these next.
will i do any damages if i will apply compressed air?
Originally Posted by sazam
(Post 4917908)
Yes, if you use too high of pressure, one could actually blow the tube off it's connections. Johnny |
