Bentley Battery Junction fuse box
Old May 13, 2019 | 03:15 PM
tqd7mb's Avatar
tqd7mb is infamous around these parts
I have a 2006 Bentley Continental flying spur with 32,000 miles. I believe 3rd owner. Started geeting white Battery low at start up. Car running rough and Trunk wasn't shutting right (would cycle up and push rear right up when appeared shut). There was NO dash lights on, first battery red light showed up today. I took down to shop and they said zero cold cranking main (Bosch non AGM battery H8).. So I decided to replace battery main to see if this was issue. When taking off the Fuse junction box the bottom of one of the bolts seemed melted. This is the 904 on attached diagram. What is this for? I replaced battery and everything running no lights or issues. Im just concerned about the melting. One last thing I hear the clicking after a few seconds like battery switched over which is weird. Key is started on right side turn
UpSideDownDesi
Southeast
14
Mar 13, 2013 07:00 PM
MikeD
Sep 28, 2012 03:12 PM
1JDM911
May 31, 2012 12:24 AM
