Bentley gtc mirror indicator
Ok so I've just fitted a new indicator lens to the car and nothing happens ie no flashing or courtesy light but when I put a meter or a test lamp on the wires it indicates there is a voltage in time with the indicator flashing I reconnect the unit and nothing.does the car have to learn that there is a new lamp unit fitted or be plugged in to diagnostic?both old and new unit power up on the Ben h and the lights work.
Hi Rico I used the same type lamps it was an exact replacement from.flyin spares.i know it works as I've flashed it up on a battery but when I connect it it won't flash I was wondering if I need to run the car for a bit as.it normally tells me I've got a bulb to check maybe if I run it it will donuts check and start flashing? God knows these things are a pain in the **** sometimes.simple.jobs made stupidly hard
