Bentley 2006 flying fault running gear workshop
Old Sep 16, 2020 | 06:42 AM
M Adam's Avatar
M Adam is infamous around these parts
hi
am having a trouble with my flying spur 2006
​​​​​​so i parked it for around 2 months and after that when i tried to start it , both batteries were dead, i was able to charge it and replaced my starter battery since it wasn't charging,and i charged my main battery but am still getting a low battery voltage every time when i start it. now the main issue is that a "fault running gear workshop" is on the dashboard and the front air suspension level is lower than normal, after many tests i was able to find that the air suspension compressor is not getting any power!, checked all wires and everything is okay, when i plug the compressor manually with a power source it works! so basically it's not damaged.
checked all the fuses and they are all fine
Anyone have any idea why the is no power reaching the air suspension compressor and the " fault running gear workshop" is always up!
JFIRL
Bentley
Apr 2, 2025 02:54 PM
zer0xp
Bentley
18
Jul 28, 2023 01:05 PM
ishotdasheriff08
Bentley
11
Nov 1, 2019 02:42 PM
Tobanla21
Bentley
31
Sep 28, 2019 01:20 AM
tqd7mb
Bentley
May 13, 2019 03:15 PM
