gt 2005 - convergence and wheel geometry
Hi Guys,
- is there any spec regarding values for convergence and wheel geometry for GT 2005? Can you share this data?
- is there a special procedure for doing this job right? Height set, car running vs turned off ? etc? I had such special experience in mercedes, with air suspension. Can you share the procedure?
- Is it true that one setting - the wheel camper angle - is not possible to set? The workshop said there is no regulation here. If they are wrong, where are the regulation points for this param.
Went to the workshop, they used 3D system, and I think they did that wrong.
