-   BMW //M (https://www.6speedonline.com/forums/bmw-m-38/)
-   -   Can't stop (https://www.6speedonline.com/forums/bmw-m/247160-cant-stop.html)
EngineRoom Jun 18, 2011 08:20 AM
Can't stop
I'm having brake problems with my 2000 BMW X5. Every 2-3 months the brakes start to shake when I brake at high speeds. New pads, and sometimes new rotors, solve the problem, but only temporarily. I drive the car hard, but not that hard. I'm tired of spending so much on brakes. Any thoughts?
MI55LE Jun 20, 2011 05:43 AM
I see you're in Colorado - are you driving up and down hills along with your speeding ? If so, learn how to drive in the mountains (not trying to be snide..)
try to stay off the brakes - use compression braking more - slow down
EngineRoom Jun 22, 2011 03:42 PM
Are you saying I should use the gears to slow down? I read that can cause more wear and tear on the transmission. On balance, better to wear out the transmission or the brake pads? Maybe you're referring to something else. Your post didn't seem snide. I'd be open to tips on mountain driving. Could be I've been doing it wrong for a long, long time.
MI55LE Jun 22, 2011 04:32 PM
I say again.....
EngineRoom Jun 22, 2011 05:33 PM
Maybe I'm already too slow. What do you mean by "compression braking"?
torment Jun 22, 2011 06:30 PM
Same thing as engine braking.
tonka858 Jun 22, 2011 06:58 PM
use the tranny to help you slow down..
your getting the rotors hot and they are warping.
tofunin Jun 28, 2011 11:43 AM
You could also have sticking caliper pistons.
FadeToBlack Jun 29, 2011 02:07 PM
Don't brake downhill. That's not how to keep a steady speed. Instead, try to learn to apply as less throttle as possible without increasing the speed. On a manual it equates to little to no throttle downhill in a single gear (of course, on a very steep incline).
nickytalon Jun 29, 2011 08:20 PM
you need to "bed in" your new rotors. google it
KJCLKBS Jul 6, 2011 12:29 PM
Check your bushings as well.
drcollie Jul 8, 2011 07:16 PM
Replace all four rotors and all four pads. That will fix 90% of that issue. Control Arms on the front end are the next thing to look at afterwards....they need to be replaced every 80K miles.
