P3 Cars BMW Digital Gauges from GMP Performance
22 Attachment(s)
Connect with your car in an entirely new way. Why settle for just a boost gauge? Sporting features available in products 3x the price, this is a swiss army knife of performance data, with design and integration that won't spoil the clean lines of your interior.
Each gauge is specifically designed to support each car's individual details, so there is never an weak point in the data being sent to you. At the current time, they have gauges built for several BMW 1-Series, 3-Series, 5-Series and Z4 models and are hard at work on even more! https://www.6speedonline.com/forums/...ine=1370964804 The E8X 128i, 135i, and 1M Gauge https://www.6speedonline.com/forums/...ine=1370964804 The E46 3 Series Gauge https://www.6speedonline.com/forums/...ine=1370964804 The E9X 328i, 335i, and M3 Gauge https://www.6speedonline.com/forums/...ine=1370964804 The F3X 320i, 328i, and 335i Gauge https://www.6speedonline.com/forums/...ine=1370964804 The E60/61 5 Series Gauge https://www.6speedonline.com/forums/...ine=1370964804 The F1X 528i, 535i, 550i, and M5 Gauge https://www.6speedonline.com/forums/...ine=1370964804 The E85/E86 Z4 Gauge Plug and Play install Quick plug and play install with zero cutting required. All power, ground, and data points come directly from the diagnostics port connector Boost/Vacuum Display High resolution boost/vacuum via diag port for FAST install. Optionally read boost via boost tap (not included). Multiple Gauge Displays Boost/Vac, Coolant Temp, Intake Air Temp, Exhaust Gas Temp, Throttle Plate, Speed, RPM with Shift-light, Battery voltage and more! Peak Recall & Run Record Recall the peak value from any mode, or record and playback 15 seconds of data from the current mode. Temperature peaks recorded in the background. Universal Aux Inputs Includes additional inputs to optionally connect any 0-5v sensor with universal settings for display ranges and bargraph displays from -999 and 9999 max values. On the Fly Configuration Menu Lockout/Display off mode, English(PSI, F, MPH) or Metric(BAR, C, KPH) selection, Adjustable boost display resolution, Ambient Calibration for boost sensor and more! https://www.6speedonline.com/forums/...ine=1370964804 https://www.6speedonline.com/forums/...ine=1370964804 https://www.6speedonline.com/forums/...ine=1370964804 https://www.6speedonline.com/forums/...ine=1370964804 To see more, click the links directly below each picture or click here see the whole line up! About P3 Cars P3 Cars exists to manufacture and provide enthusiasts with ultra high quality custom integrated gauges that have been tried, tested, and are found to out shine and out perform the competition. P3cars has grown to become the #1 most popular resource for integrated Volkswagen, Audi and BMW gauges! We make the best custom integrated gauges you will find, period. P3=Precision, Passion, Performance |
We have installed one of these on our own shop cars so if you have any questions, we can definitely help you out!
I installed one on my '13 F10 M5.. did it myself. Just needed a torx bit for the cordless screw driver and some zip ties for a clean install. Took maybe 15 minutes. Very cool accessory to have. Would recommend to others.
That's sweet
Thanks everyone!
Let us know if you have any questions. |
cool
