x5M (F85) & X6M (F86) Personal Tuner Solution | Velosdesignwerks
Hey Members,
Our Personal Tuner solution for the F85 X5M & F86 X6M platform. This particular solution is completely plug and play and ready to go out of the box. Install is also straight forward and our team is available for technical support. Installed it on our X5M that first week we received it a few months ago as well as a few others to gather more data.
The F85 X5M & F86 X6m boast an amazing maximum output of 575HP at roughly 6200 rpm which is a 4% increase over the previous model. Peak torque is increased by roughly 10% giving this version roughly 70 lb ft of torque over the previous model. While BMW has done an amazing job with the vehicle and not to mention the new 8 speed transmission there was still some power left on the table and our engineering team has spent countless amount of hours in R&D to provide a reliable tune while keeping all safety parameters in tact.
The Velos Personal Tuner will boost your X5M & X6M performance by an impressive 97hp and over 108lb ft of torque. We have done testing in both favorable and unfavorable conditions and bring you the results from the unfavorable conditions exceeding temperatures of 105 degrees Fahrenheit. The Velos Personal Tuner requires no cutting and the simple install can be done in under an hour. Benefits include improved power throughout the entire rpm band, sportier throttle response, smooth power delivery, as well as a slight improvement in MPG. With our preset calibrations the power delivery from 3200 rpm is smooth so traction is still possible with a gradual increase that will unleash your M’s true potential to the 7500 redline, providing you with useful power in an RPM range where the vehicle will spend the majority of its time. Optimized for vehicles using gasoline with an average octane rating of 90-93 peak gains are realized at 5400 rpm.
The Velos Personal Tuner for the F80, F82, and F83 platform is engineered with a multi channel controller that uses RPM based integration which enables our team to provide a refined power curve much higher than that of the factory. With an M our engineers felt it was necessary to maintain the factory like characteristics even when increasing the vehicles HP&TQ output over 15%. All of this is accomplished well within factory safety parameters making this upgrade a must for the enthusiasts looking to maximize their M’s performance without any compromise.
PM FOR BEST PRICING
http://velosdesignwerks.com/product/...software-2015/
- +108 TQ
- + 97 HP
- Improved Peak Gains
- More linear power curve
- 100% Plug and Play (no cutting or splicing)
- 100% Reversible
- Include by pass plug
PM FOR BEST PRICING
Yeah we are spoiled over here with the weather, but one more month and you'll be enjoying again!
GMP Performance
Aug 2, 2017 02:06 PM
albert@velosdesignwerks
BMW //M
Apr 18, 2016 09:30 AM
BMW //M
Jan 7, 2016 09:21 AM
