Porsche 14mm Bolt-On Wheel Spacers with Studs and Alu Nuts 15% Off special
Old Oct 20, 2012 | 12:56 AM
Nello@Maxspeed's Avatar
Nello@Maxspeed is a jewel in the roughNello@Maxspeed is a jewel in the roughNello@Maxspeed is a jewel in the rough
Hello everyone , we are currently running a special for 6speed members on our amazing 14mm Bolt-On spacers with studs and aluminum nuts. These are bolt-ons, you will bolt these directly to your hub using your factory porsche oem bolts , this allows to marry both the hub and spacer has a one piece. These make it easier for wheel removal and wheel installation, this is very practical if you track your car and have different wheels for track days, these also improve the appearance of your Porsche by pushing out the wheels a little for a wider look and improve handling by increasing the track of the car, they can also be used if you installed an aftermarket wheel and need to push out the wheel. Normally most Porsches with factory wheels look best with 14mm spacers, we have been selling 14mm spacers for years for the back wheels. They are hub centric and fit perfectly on your hub. If you have seen the porsche factory bolt-on spacers these are essentially the same but porsche makes them in 17mm thickess I have seen the porsche spacers used at factory on 997 C4S models equipped with GT3 wheels and Porsche used a bolt-on spacer to make up for the widebody of the C4S that explains the 17mm size...
For 6speed members use "spacers15" coupon code and get 15% off your entire order.
Any questions please let me know.
Nello
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
PelicanParts.com
993 Vendor Classifieds
Aug 18, 2015 03:55 PM
PelicanParts.com
Aug 18, 2015 03:51 PM
