:: ECS Tuning :: 986 Air-Oil Separator | Starting at $39.95!
One of the more often neglected systems on modern engines, crankcase ventilation parts must be functioning properly for a host of engine operations to take place.
An improperly sealed PCV system can result in pressure losses at the cylinder head, altering intake manifold pressure, allowing oil into the combustion chamber, and potentially throwing engine trouble codes. ECS offers the Air-Oil Separator for your 986 Boxster, ensuring an air-tight seal for all vacuum-driven accessories throughout the vehicle and eliminating trouble codes and blue/grey smoke from the exhaust.
Click Here for more information
When the separator fails, you will begin to see a large increase in the overall vacuum in the engine crankcase. In the most extreme cases, the air-oil separator fails to separate the oil from the air, and oil is then sucked into the intake manifold. The oil is then burned up in the combustion process, producing grey/blue smoke in the exhaust.
Jul 29, 2019 11:13 AM
ECS Tuning - VW
Aug 25, 2015 02:54 PM
ECS Tuning - VW
Aug 24, 2015 01:51 PM
ECS Tuning - VW
Aug 19, 2015 02:15 PM
