KA Motorsport 981 Exhaust PowerKit
+ 25 Hp & + 20 Tq Gain.
- 200 cell HJS “HD” Sport Catalysts. - 25 lb. weight savings over OEM system (Weighs 59 lbs. (27,0 Kg), OEM weighs 84 lbs. (38Kg). - 2 1/2" Tubing (63.5 mm). - 2 x 3.5"(90 mm) Round Tips. - Motorsport merge collector. - Intoxicating growl at idle, partial throttle and wide open throttle. - T 316 stainless steel for improved durability over T 304. - Minimal Resonance / Drone in the cabin compared to the competitions full exhaust systems. - “Aero Quip” style motorsport muffler connections with a single gasket and flange at the header to ensure a leak free exhaust. - Does NOT interfere with emissions and will NOT trigger the check engine light. - ECU programming (software) is NOT NECESSARY. - Under load (moving): 85dB* below 3000 rpms - Under load (moving): 102dB* max $5000.00 https://cimg4.ibsrv.net/gimg/www.6sp...0669f9d66c.png |
