▀▄▀▄ Vivid Racing | Cayman/Boxster Exhaust / Headers
Old Jul 15, 2016 | 12:56 PM
vividracing's Avatar
Vivid Racing Presents: Agency Power Boxster / Cayman Exhaust parts
PM, call, or email for FORUM Exclusive Pricing!
Austin@vividracing.com | +1.480.966.3040 x246 | www.vividracing.com
Agency Power Exhaust mufflers Dual Tip MSRP $700
Agency Power has developed and tested this exhaust system for the Porsche 986 Boxster. The all T304 stainless steel exhaust features a mirror polished finished, thick flanges, OEM fit, and an incredible sound. Producing an amazing sound which gives the Porsche a nice race tone, this exhaust is still comfortable for daily driving. As tested on a Mustang Dyno, the Agency Power Porsche 986 boxster exhaust produced an impressive 23HP and 11ft/lbs of torque. Add an Agency Power ECU upgrade with an intake kit and your power will keep climbing!
Features:
Incredible race exhaust tone
Improved Horsepower and Torque 23HP & 11ft/lbs
Bolt-on installation
Made using high quality T304 stainless steel
Polished to mirror finish
Fitment:
Porsche 986 Boxster 98-04
Porsche 987 Boxster Race Header MSRP $1400
Ideal for the track and race inspired 987 Cayman enthusiasts, Agency Power has released its new cat-less header! This header is designed for optimized exhaust gas flow and maximum power. This product is recommended for track/off-road use only. You will feel the difference the Agency Power header has to offer the moment you fire up the engine. The mandrel bent runners and large collectors remove exhaust restriction over the factory header. Agency Power is recognized worldwide as an aftermarket the leader in complete exhaust system upgrades built with the highest quality, designed for optimal flow to produce amazing sound and powerful gains. Pair this item with one our other Agency Power products such as our tuning solutions to see the best results!
Features:
Includes gaskets for a leak-free exhaust seal
Constructed from T304 stainless steel
CNC mandrel-bent primary pipes for maximum horsepower & torque
Direct bolt-on replacement for the OEM headers
Compatible with OEM center muffler or Agency Power Muffler
Optional 02 Spacers available to help keep the C.E.L. off.
section: headers
connects to: Rear muffler
style: 3 to 1 merger
material: T304 stainless steel
Fitment:
Porsche 987 Boxster 2005-2008
Porsche 987 Cayman 2005-2008
Agency Power Exhaust system 987 MSRP $1200
Agency Power has developed and tested this exhaust system for the Porsche 987 Boxster and Cayman vehicles. The all T304 stainless steel exhaust features a mirror polished finished, thick flanges, OEM fit, and an incredible sound. The twin muffler exhaust system can be used with the OEM exhaust tip or our optional dual style chrome exhaust tip. The exhaust tip is easily fitted on to the OEM y-pipe and can be adjusted as needed. The exhaust is more free flowing with the reduction of the 2 additional catalytic converters. The exhaust will then give you much better throttle response compared to the stock system. Producing an amazing sound which gives the Porsche a race tone, this exhaust is still comfortable for daily driving. As tested on a Mustang Dyno, the Agency Power Porsche 987 exhaust produced an impressive 23HP and 11ft/lbs of torque. Add an ECU upgrade with an intake kit and your power will keep climbing!
This exhaust will not fit the 987.2 without modification.
Note: Does not include tips.
Agency Power 981 cayman Exhaust system MSRP $1295
Agency Power has become well known for their high quality exhaust systems. The Porsche 981 Boxster was released in the summer of 2012 with a total redesign from the previous 987 chassis design. The direct fuel injection Porsche which is available in either the 2. 7L or 3. 4L engine, lacks the sports car grunt. To meet regulations and sound restrictions, the factory exhaust does rob alittle power and performance which can easily be uncorked. The new Agency Power exhaust system for the Porsche 981 is a complete header back kit. It features secondary cat bypass pipes and a dual muffler with a large dual tip. With an all stainless steel construction featuring exquisite TIG welding and polished piping, the exhaust system including mounting bracket is a direct replacement for the OEM unit.
As tested on our Mustang all wheel drive dyno, the muffler in comparison to stock added a peak of 7whp and 11ft/lbs of torque over stock. Because of the sensitivity of the traction control, the car must be tested in AWD mode which typically yields lower numbers then a RWD test only. However the most impressive gains were between 2500 and 4300 rpm’s which are typical driving conditions to get you from 0-60 much quicker.
The exhaust has a more aggressive tone then stock but is still very comfortable for daily use. It is designed to fit the 2013 and up Porsche 981 Boxster and Cayman. It will fit the Non-S, S, and GT4 versions. No cutting or welding required. Optional headers sold separately. All Agency Power parts come with a limited lifetime warranty when you fill out the form here.
Agency Power 981 Catted headers MSRP $1995
The Porsche 981 platform which replaced the 987 Boxster and Cayman still features a DFI 2.7L or 3.4L engine. However there are big performance gains to be had in the exhaust system. A normally aspirated engine does not want to lose alot of backpressure as this will affect low end torque. With the right combination of exhaust flow and backpressure, getting more horsepower and torque can be easily obtained. Not only that, your sports car will actually sound like it should!
The all stainless steel headers feature precision TIG welding with a beautiful merge collector. The headers feature high flow catalytic converters. Because of the increased exhaust flow, these headers can trigger a check engine light. We recommend aftermarket ECU tuning to get rid of this CEL if it appears.
With the addition of our Agency Power performance muffler, the Porsche 981 Boxster S gained 11whp and 24ft/lbs of torque. These fit all S and Non S Porsche Boxster and Cayman 981 from 2013 and on.
Ordering:
Phone:
You can reach me directly by calling +1.480.966.3040 x246 to place your order over the phone.
Payment Methods:
- Credit/Debit Cards (Visa, MasterCard, Discover, American Express)
- PayPal
- Affirm — Now you can finance your parts!
- Bank Wire
- Bill Me Later
- AZ Orders will incur 7.8% sales tax
- All international orders (outside of US and Canada) require Bank Wire or PayPal
Shipping:
We have very competitive worldwide shipping rates. Most orders leave via FedEx, however we do use UPS, DHL, and various freight companies. The most efficient shipping method takes precedence. Expedited shipping is available by request.
Hours of Operation: We do not observe Daylight Savings Time in Arizona
March-October: M-F 9am-6pm PST
November-February: M-F 8am-5pm PST
We are closed for business Saturday and Sunday
Contact Information:
Phone: 480.966.3040 x246
Email: Austin@vividracing.com
Website: www.vividracing.com
Please feel free to contact me via PM, Email, or Phone if you have any questions.
