996 wheels for 986
996 wheels for 986
I am looking at some stock 2003 C2 996 wheels. I understand the fronts fit with no issue, but there is an issue in the back.
What do I need to fit these on the rear of the Boxster?
Guest
Posts: n/a
You'll need a set of spacers...I don't remember exactly which size...I *think* it was in the vicinity of 15 or 17mm spacers, but I would definitely double check on that...
Thank you all for your responses.
Would the tire rub the fender well with 17mm spacers on?
Also would I need to buy longer lug nuts to account for the spacers (who sells them)?
What brand spacers do you recommend (and where to buy it)?
Thank you in advnace for your help.
I had some 8mm spacers lying around so I decided to try them out. 8mm is not enough. The wheel was hiting the shock. So I doubled up for a total of 16mm, it seem to work. The lug nuts were no long enough to even hold the wheel on.
I called Suncoast Porsche and they recommended these:
http://e-partssales.com/Merchant2/me...ry_Code=986sus
So I'll get them and let you know how it turns out.
Thanks for all the help.
PelicanParts.com
996 Vendor Classifieds
Aug 18, 2015 03:45 PM
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 18, 2015 03:43 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
