Thanks Tool Pants.
Thanks Tool Pants.
Thanks Tool Pants. Pictures would definitely help. Do you know how to change the headlight bulbs? I don't see an opening from anywhere.
-Jesse
-Jesse
You need to remove the headlight assembly from the car to get to the bulbs. Instructions are in the owners manual.
Unlock the headlight from inside the trunk with the tool that is in the tool kit. If you do not have the tool then use a 5mm socket. Then the headlight will slide out from the fender. The 2 main bulbs are under a cover on the back of the headlight. Jeff
Kai@ELITEMS
08-06-2016 09:50 AM
Kai@ELITEMS
10-01-2015 04:34 PM
Kai@ELITEMS
Bentley
10-01-2015 04:33 PM
Kai@ELITEMS
Ferrari
10-01-2015 04:32 PM
Kai@ELITEMS
Lamborghini
10-01-2015 04:32 PM
