New GT-2 Style rear wing for the Cayman
Old Aug 2, 2009 | 10:50 PM
autobahn it's Avatar
autobahn it has a spectacular aura aboutautobahn it has a spectacular aura aboutautobahn it has a spectacular aura about
My 2 cents: Cut the side pieces down just about 3 inches or so. Then move the top wing towards the rear of the car & center it on the 2 side pieces. Right now the wing (to me) sits too high & too forward. If the sides were centered on the top wing, I think they'll look MUCH better. Doing that will also allow you to bring the wing down closer to the car... and dont forget to cut about 3 inches off the top of each of the side mounts. My 2 cents. ;o)
I attached a photo of 2 cars we've modified the tails on... & made them unique, and pretty "balanced" looking too.
I think you can work with what you have... but will need to do something with the side pieces (even though we can't see it from your photos very well). They probably look too tall & awkward on the car from certain angles (without a base). The base on the Techart tail gives an "anchored feel" to the tail. The shorter you can make the side pieces, I think the better the tail will look. Also... moving the tail towards the rear of the car more, will give the car a more stretched out look... that I think looks nice. Not a major movement... just 4 inches or so backwards I think will do the trick. ;o)
Do I get any change back for my 2 cents? hehe
Old Aug 3, 2009 | 08:13 PM
Fluid987's Avatar
Fluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond repute
autobahn it
Yes You get a full Dime for that sugestion, I like It .
Yes I agree if they can reduce the outer wing part that goes downward and shorten it some that would give you that option of moving it back 4" s
I really like they wing you posted .
They did reduce the heighth of the wing from the techart styed one and the current wing sits 3/4 inch from the rear deck . like your sugestions though ,awsome
Old Aug 3, 2009 | 11:47 PM
Gracias. I like the look of the top wing being just off the hind quarters of the car by about 1 to 2 inches. Seems to make the wing look more "part of the car" instead of looking tacked on.
Even though the tails I've put on the 2 cars in the photos look way-wild, I think they still seem to blend into the body styles... if that's possible.
I think you are onto something with that wing. The crappiest part of trying to do what your doing, is, the tips of the wing (I think) are going to want to hit/touch the quarterpanels, before you can lower it as much as you want to. Moving the tail-top backwards will help you lower the tail-top, more though. ;o)
Old Aug 4, 2009 | 07:48 AM
pearlcoupeg35's Avatar
pearlcoupeg35 has a reputation beyond reputepearlcoupeg35 has a reputation beyond reputepearlcoupeg35 has a reputation beyond reputepearlcoupeg35 has a reputation beyond reputepearlcoupeg35 has a reputation beyond reputepearlcoupeg35 has a reputation beyond reputepearlcoupeg35 has a reputation beyond reputepearlcoupeg35 has a reputation beyond reputepearlcoupeg35 has a reputation beyond reputepearlcoupeg35 has a reputation beyond reputepearlcoupeg35 has a reputation beyond repute
Mreh
Old Aug 4, 2009 | 11:51 AM
Fluid987's Avatar
autobahn it
You are Right on with you sugestions !! They tried lowereing the height by just shaving down the 2 pilar parts that bolt on the rear but on the first try the ends of the wing that go down rubbed the 1/4 panels ,OUCH!!
By trimming down those ends that bend down if would give them them several options that were not available before. Will see if there is an updated photo or some new tweaks that have been updated.Thanks for your help
Old Aug 9, 2009 | 02:58 PM
advantyper's Avatar
advantyper is a splendid one to beholdadvantyper is a splendid one to beholdadvantyper is a splendid one to beholdadvantyper is a splendid one to beholdadvantyper is a splendid one to beholdadvantyper is a splendid one to beholdadvantyper is a splendid one to behold
Wow, nice work
do your shop sell that modded spoiler for Cayman?
Old Aug 9, 2009 | 03:03 PM
notquitefob's Avatar
notquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud of
i like straight wing base like this
but maybe have a smaller wing blade that's a little bit narrower than this.
Old Aug 10, 2009 | 12:04 PM
Fluid987's Avatar
notquitefob
That wing Is HUGE!! looks like a Gt Cup Race car.
I guess if I had a turbo I could Justify it though
Kinda reminds me of the Speedart one but bigger
Old Aug 11, 2009 | 12:35 AM
StuartsPNB's Avatar
StuartsPNB is a splendid one to beholdStuartsPNB is a splendid one to beholdStuartsPNB is a splendid one to beholdStuartsPNB is a splendid one to beholdStuartsPNB is a splendid one to beholdStuartsPNB is a splendid one to beholdStuartsPNB is a splendid one to behold
Any specs on the wing itself?
Old Aug 11, 2009 | 08:04 AM
I would prefer the factory aero kit with it's fixed wing simply because that wing actually was designed by engineers and tested in the wind tunnel. I wish someone would make a replica of it lol
Old Aug 11, 2009 | 09:22 AM
advantyper's Avatar
Tess in UK, have a replica one of the factory aero wing, its around $1400 usd shipped over here.
Old Aug 11, 2009 | 10:00 AM
i've been following Tess' threads on his replica wing but that project hasn't made any progress for a long time now. The last I heard, which is months ago, he was still trying to fabricate the piece that replaces the factory wing blade.
I would be down to do a group buy esp. since I know there are a number of people also interested in the factory aero kit, especially since it's an actually proven design.
time to stop the thread jack.
I think the GT2 style wing looks great. I've always liked the techart GT wing, but hated that base that comes with it.
Old Aug 11, 2009 | 10:08 AM
Fluid987's Avatar
notquitefob
I will have this new Gt-2 styled wing on my cayman in 2 weeks or so . I have donated my car to be the Guinea Pig for the project .
Basically its a going to be a scaled down Tech Art styled wing .a little lower ,smaller end parts that go down and mounted on the rear hatch .Its looking like the Gt-3 rear wing some .No base part or rear brake light and right around 1K unpainted I have great trust in NRAA that it will look great
Old Aug 11, 2009 | 10:17 AM
awesome. keep us posted !
would love to see some pictures from different angle if possible.
Old Aug 11, 2009 | 11:20 AM
CosmosMpower's Avatar
CosmosMpower has much to be proud ofCosmosMpower has much to be proud ofCosmosMpower has much to be proud ofCosmosMpower has much to be proud ofCosmosMpower has much to be proud ofCosmosMpower has much to be proud ofCosmosMpower has much to be proud ofCosmosMpower has much to be proud ofCosmosMpower has much to be proud of
Doesn't quite flow with the shape of the car.
