Porsche 981 Boxster/S & Cayman/S Ohlins Road & Track Coilovers - GMP Performance
Old Jan 27, 2017 | 05:15 PM
GMP Performance's Avatar
Site Sponsor
981 owners, are you ready to level up your drive? Öhlins has released their Road and Track coilovers for your Boxster or Cayman.
About R&T Coilovers
A more than 30 year long tradition of high-end racing commitments
and state-of-the-art solutions within advanced suspension
technology is now available for street cars all over the world.
The focus has been clear from the very beginning – superior road
handling without sacrificing comfort in your day-to-day transports.
The time of compromises is over.
We have also added a clever light-weight design with a majority of
the parts in aluminium and on top of that all shocks have suffered
through vast corrosion tests according to ISO9227. The end result
is a 2-year limited warranty on all of our products - worldwide.
Öhlins Road & Track team has extensively tested a wide variation
of springs to find the right balance between road and track use.
By testing in different conditions on road as well on track, the listed
spring rate is what we strongly recommend you to use.
FEATURES
General
> DFV (Dual Flow Valve)
> Rebuildable
> Corrosion salt spray tested (ISO 9227)
> 2 year limited warranty
> Height adjustable
> Springs ordered seperately
Front
> McPherson strut
> Single bleed adjuster
> Spring preload adjuster (approx. 8 mm lower than standard)
> Coil springs
> Dustcovers
> Use with original top mounts
Rear
> Conventional shock absorber
> Spring preload adjuster (approx. 10 mm lower than standard)
> Coil springs
> Dustcovers
Now what is DFV, you may ask? It stands for Dual Flow Valve technology – and it sets Öhlins apart from our competitors. Only Öhlins has DFV technology on its road and track products.
With DFV, the dual flow valve gives the same characteristics on rebound as it does on compression, thanks the damper fluid having a consistent path of flow in both directions. This means that the wheel and tyre can quickly and effectively resume their important position back on the ground, providing grip and traction. The new Öhlins R&T range uses DFV technology on every single fitment, making it the perfect upgrade for the enthusiast that needs comfort and agility in the one unit.
For more on these awesome coilovers and DFV technology, click here.
Old Jan 31, 2017 | 05:18 AM
Barryc's Avatar
Barryc is infamous around these parts
Can I get a price installed on 2016 boxster spyder? I'm in NC and can come to you. Would like to have the car corner balanced too if you guys can do that. thx bc
Old Jan 31, 2017 | 10:44 AM
Site Sponsor
Message sent!
Old Feb 2, 2017 | 05:31 PM
betlion's Avatar
betlion is infamous around these parts
pricing for 981 cayman
Old Feb 3, 2017 | 02:29 PM
Site Sponsor
Pricing is available here: Ohlins 981
I've sent you a message with our forum special!
Old Feb 27, 2017 | 03:36 PM
Site Sponsor
Messages replied!
Old Mar 22, 2017 | 11:27 PM
2010Panny4S's Avatar
2010Panny4S is infamous around these parts
how height adjustable is this system. 2012 Cayman R
Old Mar 24, 2017 | 08:14 AM
Site Sponsor
Typically around 2.5" of adjustment for most coil overs. I can certainly check on the exact specs if you have a certain goal in mind. Is your goal performance or to lower the car as much as possible?
The 2012 Cayman R is a 987 Cayman, which will be a different kit than the 981 system. Ohlins has a 987 kit in development, and we offer a few other brands for the 987 as well.
Old Mar 24, 2017 | 11:33 AM
Pls PM me what you have and prices. It's the wife's car not mine.
Old Mar 28, 2017 | 02:00 PM
Site Sponsor
Messages replied! Thanks everyone!
Old Jul 20, 2017 | 08:08 AM
Site Sponsor
Orders shipping!
