Vorsteiner V-ff for 981 BACK IN STOCK!!
Back in stock! A 981 specific fitment in Vorsteiners classic looking V-FF 101. These are built to fit the 981 perfectly without any spacers or hub rings. Flow forged wheels are the perfect way to get a lightweight, strong, and high quality wheel without paying the high amount or waiting 2 months for a set of forged wheels. You can check out some more on the forging process below
An initial casting unique to Flow Forging Technology is placed onto a steel rim and mold and prepped to be processed
Extensive heat and pressure is applied using three individual rollers to shape the aluminum to the rim mold.
The individually shaped rollers fortifies the barrel to the specified width and density allowing for a stronger wheel using less material.
The molecular compound of the aluminum significantly hardens in a streamline direction resulting in a wheel with a higher impact tolerance and considerably lighter in weight.
981 Fitment V-FF 101-Carbon graphite
20x8.5 +45 23 lbs
20x10 +38 23.4lbs
