Racing Yellow Porsche Cayman GT4 with BBi Suspension, Roll Bar, Wing Uprights
Old Dec 8, 2017 | 12:35 PM
BBiAutosport's Avatar
BBiAutosport is infamous around these parts
Attachment 1
Racing Yellow Porsche Cayman GT4 with Full BBi StreetCup Suspension, Roll Bar, and Wing Support
Bound for Sonoma Raceway, we would like to present this Racing Yellow Porshce Cayman GT4 build we recently completed. We gave it a proper setup with our complete BBi Autosport StreetCup Roll Bar Suspension Package along with our Extended Wing Supports. Here are some pictures of the build that we would like to share:
Vehicle Specifications
Safety Upgrades
  • BBi StreetCup Roll Bar
  • Schroth GT3 Harnesses HANS
Suspension Upgrades
  • BBi Bump Steer Kit Front
  • BBi Adjustable Thrust Arms Front Pair
  • BBi Adjustable Thrust Arm Bushings Front Pair
  • Porsche Motorsport Lower Control Arm Inner Spherical Bearing
  • Tarett Engineering Adjustable Sway Bar End Link Front
  • BBi Rear Toe Adjustable Toe
  • BBi Adjustable Thrust Arms Rear Pair
  • Tarett Engineering Adjustable Sway Bar End Link Rear
  • Swift Spring Kit
Exterior Upgrades
  • BBi Extended Wing Supports
BBi GT4 Safety Package
  • BBi Autosport GT4 Harness Bar Bar Satin Black
  • BBi Autosport 991 GT3 / 981 GT4 Sub-Strap Mount
  • Schroth Profi II - GT3 Racing Harness HANS Specific
BBi GT4 Roll Bar Features
  • Chrome moly steel tubing utilized for excellent strength to weight ratio
  • Modular construction to allow access to engine for servicing without removing entire rollbar
  • Shoulder harness mounting crossbar positioned at appropriate height as per Schroth's instructions
  • TIG welded and utilizes "X" braces on rear section for superior strength and rigidity
  • Mounts to frame structure and rear strut tower to provide strongest mounting points and maximum protection
  • Utilizes laser cut mounting plates & inner diameter tube clamps that are CNC turned and milled for a precise fit
  • Designed to work with stock or any aftermarket seats on the market
  • Minimal affect on seat travel to accommodate taller drivers
  • Can be used with stock seat-belts or 6 point harnesses for track use
  • Designed to work with wrap-around style harnesses while optional eyelet bolt provisions are available for clip-in harnesses
  • OEM fit & finish. The main hoop contours entire arch of the roof with an even curve
  • Finished in satin black powder coat. Other colors available
  • Bolt-in installation requires no drilling and minimal carpet trimming
Product Link: http://www.bbiautosport.com/products...etcup-roll-bar
Schroth Racing Profi-II HANS Harness, Porsche GT3 Specific Black
Porsche GT3 Cup Cars come with Schroth belts direct from the factory. They are specific because of the lap belt attachment. They have a sewn-in bracket that fits perfectly on the factory mount. Standard belts require additional fabrication and a spacer to make them work. These are a bolt-in replacement which is much easier. The sub-straps have no adjusters to fit correctly in the vehicle, and the shoulder belts are shorter to reach the works cages with minimal excess.
  • Shoulder: HANS Specific 2" tapered to 3" Shoulders
  • Lap: Sewn-in B43A (GT3 Specific Hardware)
  • Sub belts: LV11 with B14 Snap-in Bracket Wrapped-in
  • Include hardware: 1 SG23 7/16" Eyebolt, 1 S3 Wavy Washer
  • Available with Pull-Down lap belts only
BBi Sub-Belt Mount Porsche 991 GT3/ GT3RS / Cayman GT4
If you have the optional Sport Bucket seats and planning to install 6-point race harnesses, then you will need this bracket. Shown here as a pre-production example, this bracket bolts directly to the seat and keeps the harnesses at the proper 10-20° angle regardless of the seat position.
Features
  • Provides mounting location for sub-belts at the proper 10-20° angle regardless of the seat position
  • Precision CNC laser cut and bent from one piece high carbon steel for superior strength
  • Stylish design with laser cut BBi logo and durable satin black Powdercoat finish
  • Attaches to seat assembly using factory mounting points with all hardware included
  • Compatible with Porsche 991 GT3 and 981 Cayman GT4 models equipped with Sport Bucket Seats
  • Made in the USA
Product Link: http://www.bbiautosport.com/products...b-belt-bracket
To improve handling, we installed our complete BBi Street Cup Suspension package along with Tarrett Engineering's Adjustable Sway Bar End Links. Our upgraded components provided the additional adjustment ranges to help maintain proper suspension geometry that not be achieved with the factory arms.
Front suspension
Front Suspension Upgrades
  • Porsche Motorsport Lower Control Arm Inner Spherical Bearing (Mono-ball) End Kit Front Pair
  • Swift Springs
Rear suspension
Rear Suspension Upgrades
  • BBi Adjustable Thrust Arm Bushings Rear Pair
  • Porsche Motorsport Lower Control Arm Inner Spherical Bearing (Mono-ball) End Kit Rear Pair
  • Swift Springs
BBi Autosport Front Bump Steer Kit
  • Helps eliminate bump steer by maintaining proper front end suspension Geometry
  • Utilizes misalignment rod ends of the arm to provide maximum articulation
  • Highly recommended for vehicles that have been lowered
  • Each kit includes pair of 2 Links
BBi Autosport Rear Adjustable Toe
  • Provides additional rear toe adjustment
  • OEM link is non-adjustable and eccentric bolt provides limited adjustment range, causing excessive tire wear and handling issues.
  • Helps maintain proper rear end suspension geometry
BBi Autosport Front & Rear Thrust Arm Kit
  • Connects the Lower Control Arm to the subframe
  • Provides precision caster adjustability
  • Spacers included for setting stock or anti-squat and anti-dive configurations
  • Each Kit Includes Pair of 2 Links
  • Fits both front and rear axles
BBi Autosport Front Adjustable Thrust Arm Bushing Kit
  • Provides two eccentric mounting points
  • Used to adjust for increasing or decreasing wheelbase, and adjustable caster.
  • A must-have for extended lower control arms (GT3 control arms or eccentric monoballs) to correct for unintended caster change
  • Compatible with all stock Porsche 996 and 997 lower control arms (including Porsche Motorsport Cup arms)
  • Sold as a set of 2 or a Complete set of 4
Tarrett Front and Rear Adjustable Sway Bar End Links
  • Simple bolt-in replacement for the factory drop links
  • Left & right hand threaded rod-ends allow for simple length adjustment to eliminate swaybar preload
  • Correctly sized, precision, Teflon-lined rod-ends for smooth and quiet operation, long life, and high reliability. No wear and rattling problems, like those seen with other designs, due to undersized or low-quality rod ends
  • Eliminates the factory compliant plastic drop link bushings that deflect under loading and quickly wear out
  • High misalignment, stainless steel spacers allow for superior bind free operation and corrosion resistance
  • Precisely connects the stock or adjustable swaybar to the front strut assembly for improved feedback and swaybar response
  • Overall length is adjustable to accommodate either stock or adjustable swaybar requirements
Corner Balance & Alignment
Finished Project with BBi Autosport StreetCup Extended Wing Supports Installed
BBi StreetCupGT4 Extended Wing Supports
Features
  • Increase 80mm Over the OEM Wing Height
  • Made of Precision CNC Machined 6061-T6 Billet Aluminum
  • Durable Hard Anodized Flat Black Finish
  • Easy to Install. No Drilling or Cutting Required
  • Designed to Use with OEM Weather Seals & Hardware
  • Compatible with Porsche 981 Cayman GT4 Model Only
  • Made in USA
  • MSRP $995.00
Product Link: https://www.bbiautosport.com/product...-wing-uprights
- jerry@bbiautosport.com
- Jerry@BBiAutosport.com
BBiAutosport
GT3/GT2/GT Vendor Classifieds
Nov 27, 2017 03:56 PM
BBiAutosport
Nov 24, 2017 01:50 AM
BBiAutosport
996 Turbo Vendor Classifieds
Nov 24, 2017 01:49 AM
BBiAutosport
997 Turbo Vendor Classifieds
Nov 24, 2017 01:33 AM
