Power Seat Removal Help
I have a 1999 Boxster with power seats, which I need to remove. However, the seats will only move forward because the switches are broken, so I cannot get at all of the mounting bolts. Is there any way to move the seats manually? Any ideas would be most appreciated.
Thanks.
Thanks.
I believe that it is the switches.
Inside the switches is a little plastic toggle thingie. These sometimes break but I don't think that you can buy the parts separately. Since you would need to replace the switch anyway, you might consider taking it apart and jumping the circuit manually until the seat is in position.
quick
07-12-2012 02:46 PM
