Boxster spoiler/tail won't come out! HELP!
Hello,
I am hoping that I can get some advice or opinions from the experts here at 6 before I make an appointment to take my p-car to the shop. Recently, my rear spoiler will not come out at the designated speed of 70 (maybe it's 75). Either way, even when I manually try to put the spoiler up with the button by the fuse box, it will only go up about 1 inch. Once in about ever 30 times that I push the button, will it actually go up. I checked when it WAS up, there was nothing jamming it or gunk, etc. Any ideas why it won't go up while driving, let alone manually? It was fine up until last week. Thanks for your information! ~Boxstergirlie :p |
Open your trunk and drop down the little panel on the Lft side. Reach up and under the rear fender and wiggle out the relay holder. Take the #3 relay ( believe) and the one below it out. Give them a couple of good raps on your driveway. Try to hit’m on all sides.
Plug’m back in and see if it helps. Worked for me last weekend. Also check your fuces. I think theres 2 for the spoiler. Good Luck, P.K |
Quote:
YOU'RE the MAN! It worked! Thank god! I had an appointment next weekend to take it in to have it looked at. They told me they'd need to keep it all day, possibly even two days. They said it could be some "fluid" that is leaking. It's not! Thank you sooo much! You saved me a bundle! :p Jody |
Great! glad it worked. Not sure how permanent a fix it is but at least your motoring and ya’ no what to knock around or replace if it happens again (those relays are $5-$10).
Oops, got a PM...maybe I wasn't so clear. |
Fluid was leaking? I've taken apart my rear spoiler before and I assure you that there is no fluid involved.
You might want to find somewhere else to take your car. |
1 Attachment(s)
Quote:
Attachment 506071 Bro |
lol! sad thing is, it was the porsche dealer that said about the "fluid". i'm thinking, as totally strange as this sounds, that is has to do with the balast from the xenon's that were just installed. the only reason i'm thinking this is because the oil light and battery light also come on the minute i turn the lights on. if i shut off the car and restart it, the lights go away. agghhhh! time to take the balast out....return it....reinstall my oem's for now and await the new balast.
thank you all for your info! |
Quote:
P.K. |
| All times are GMT -6. The time now is 05:23 AM. |
