Cayenne Lowering Module
Just wanted to give you guys a heads up that I've decided to leave our popular Cayennee Lowering Control Unit on sale for the holidays!!:)
You can find the sale here: http://www.championmotorsport.com/pr...cmslcu955t.htm Check this thread for more pictures and answers to a lot of the most common questions about the unit: https://www.6speedonline.com/forums/...-lowering.html Our Lowering Control Unit work on all Cayenne models equipped with factory air suspension. Happy Holidays!! :D |
This kit is also available for the 2011 Models =)
BUMP for a great Christmas gift idea. :)
Will this automatically lower the car to " loading level " when parked?
Originally Posted by PBR ME
(Post 3103998)
Thank you for the speedy response!
Tom, how is this lowering module different from all the others on the market?
Also, do you offer any deals to board memebers? |
It will work in a 2011 Cayenne S ?
Originally Posted by luiscarlos
(Post 3183876)
will it work on 2004 cayenne S?
Originally Posted by Dougb756
(Post 3219250)
Question:
If your lowering module doesn't allow you to drive in "Loading mode" but allows you to drive in "Sport mode" at 55MM lower than the previous "Sport mode", wouldn't that be like driving in "Loading mode" (Or even worse). What effect on the bags do these lowering modules have? In other words, are they safe to use? |
Originally Posted by Saggio
(Post 3691925)
Question:
If your lowering module doesn't allow you to drive in "Loading mode" but allows you to drive in "Sport mode" at 55MM lower than the previous "Sport mode", wouldn't that be like driving in "Loading mode" (Or even worse). What effect on the bags do these lowering modules have? In other words, are they safe to use? With our module the bags will ALWAYS be inflated so you avoid any potential damage. |
Originally Posted by Tom@Champion
(Post 3692069)
Essentially, when you're in "loading mode", the airbags are completely deflated. For one, the ride is TERRIBLE with no air in the bags...the car bounces all over the road. Second, it can cause damage to the bags themselves.
With our module the bags will ALWAYS be inflated so you avoid any potential damage. Do you see what I'm getting at? Nobody can ever give me a straight answer on this. |
(Post 3692630)
How is it possible to be 55mm lower on Sport Mode and not have the bags deflated? Loading Mode isn't even 55mm lower than Sport Mode.
Do you see what I'm getting at? Nobody can ever give me a straight answer on this. On the 955 models, you can go the full 55 because they come much higher from the factory. |
