Which of the 2008 is the best for offroad? The V6?
Old Jul 14, 2008 | 06:10 AM
motoadve's Avatar
motoadve is infamous around these parts
For semi hardcore offroading, which Cayenne will be the best?
Also is it possble to rise the height of a stock Cayenne?with stock suspension?
Old Jul 14, 2008 | 06:13 AM
Christian's Avatar
Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !Christian Is a GOD !
I would look into the V8. The V6 has very little power
Christian
Old Jul 14, 2008 | 06:19 AM
motoadve's Avatar
So the 290 HP is not enough?
My 1998 ML320 has 215 HP and is pretty good offroad
Old Jul 15, 2008 | 01:35 AM
racer_65's Avatar
racer_65 is infamous around these parts
The Cayenne is a heavy car. To answer your question, my '06 Cayenne S has 340 HP, and I think it's barely enough power.
Old Jul 15, 2008 | 01:52 AM
Fantasma's Avatar
Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !
the GTS with 405HP is pretty good though in terms of mass vs acceleration.
if you want to offroad get yourself a Toyota FJ Cruiser... very good offroad even with stock tires, but you have to be a good driver too.
Old Jul 15, 2008 | 03:40 AM
Speedshaq's Avatar
Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !
I would choose a Cayenne S.
Old Jul 15, 2008 | 08:48 AM
Dennis C's Avatar
I don't think a GTS would be a good offroad option because of the wheel and tire combination.
I think the new V6 is much better than the old V6, but I would still choose a V8. Go for the 18-inch wheels with suitable tires and it will be excellent off road. If you add the PASM option so that you can raise and lower the suspension, it will be even better.
Old Jul 15, 2008 | 02:53 PM
Cpa4S's Avatar
Cpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to behold
if you want serious off road then make sure you get the the air suspension and PDCC which can de-couple for off road.
go for a V6 if off raod is serious - the money saved on the motor more than pays for the above options.
on the highway you may well grow to regret the V6 - but depends on your driving mix.
Old Jul 15, 2008 | 08:01 PM
deputydog95's Avatar
deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !
I can't speak for it's off road capability, but there is more than enough power for street driving in my V6. Considering it's a truck, it's really quick. I suppose you will never regret having too much power; but for a SUV, I think the hp in the 6 is fine. Generally I reserve my "hot rodding" to much lower, lighter vehicles.
Not to mention my wife gets around 20mpg in it. I get slightly less
Old Jul 16, 2008 | 05:50 AM
SRatha's Avatar
SRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud of
the Range Rover Sport TDV8 ;-)
Old Jul 16, 2008 | 11:04 AM
wilfred's Avatar
wilfred is infamous around these parts
The Cayenne Base/V6 with 17" wheels & PASM (air suspension).
With the 17" wheels, you have more than a handful of choices with all terrain tires to choose from. With 18", there is only one I found the last time I looked. And with 19" & 20", I did not find any. Having the right tires is probably the most important factor for offroading. Also bear in mind the brake calipers are bigger on the V8s (S, GTS, Turbo) and the smallest wheels you can getaway with is the 18" to my understanding (not 100% sure). This is why I said get the Base/V6.
I am sure you can put different size tires on any of the wheels but you might throw off the computer then you will have to get it re-calibrated. I have no idea if this is something easily programmable by your local Porsche dealership or if this is something more involving than you want to deal with? Bear in mind the computer in the Cayenne is pretty high tech in my opinion as I recall there is a list of tire size to choose from if you make any changes in sizes.
Although I have only driven the old V6, which I do find underpowered for city driving. I wouldn't worry about it because the new V6 seems to have been upgraded by a lot and the fact for offroading, you only go 5-15 MPH most of the time.
Lastly for the suspension, just get one with PASM and that should be satisfactory for most people. If you need anything more than that, you are either looking at the wrong vehicle for your kind of offroading or you are looking at a lot of custom fabrication which I doubt that is something you are looking to get into?
Old Jul 17, 2008 | 08:18 AM
EMart's Avatar
EMart is infamous around these parts
That is correct.
JWrightPNH
Nov 9, 2015 03:40 PM
Marcus Yong
New Member Introductions
Oct 2, 2015 03:30 PM
gliozzi
Bentley
Sep 29, 2015 09:27 AM
gliozzi
Bentley
Sep 28, 2015 03:27 PM
