Calipers not releasing?
I have a 2008 Cayenne V6 and wondering if anyone else has this problem.
Car has an intermittent squeal when I let off the brakes and as the car begins to roll. It's a low-pitched humming sound. It's been to the dealer a number of times - first they claimed brake dust buildup, then they replaced the rear pads and rotors. That seemed to help for about 6 months but now the noise is back.
So I took it in again today and they said they want to check to make sure the calipers are releasing properly. They think it might be related to the "hill stopper" that keeps the car from rolling back on an incline.
Anyone else experience this? What was the fix?
Thanks!
Thanks!
I don't know the fix, but my 2009 Turbo S does the same thing. A good power wash of the calipers clears it up for anywhere from a couple of days to a couple of weeks but it does not seem "normal" to me. I have not yet taken it in though.
I've personally fixed this issue on plenty of Cayennes. The Dealer should be able to clean everything up and get it to go away. I haven't address that particular brake noise on the new turbo S', but brake noises on apply with the turbo s' is kinda normal, goes with out saying if it has PCCBs.
I started experiencing this issue at around 21K miles. Hosing with water does help for a few days, so dust plays a part; however, I finally found out the root cause. If you look at the front rotors, you'll probably see a ridge caused by the pads wearing down the center part of the rotor. When you release the brakes, the pads slightly scrape against this ridge, causing the squeaking noise. The only solution is to replace the rotor.
Thanks for all the replies.
Agreed that cleaning the wheels only takes the noise away for a few days, then it's back again.
An update from my end - the dealer did some tests and sent the data back to the factory. They got authorization to replace the hydraulic control unit. Factory also asked them to check the travel of the pads and calipers, maybe replacing the control unit won't be necessary.
For what it's worth, my dealership has seen this on only one other car. It doesn't appear to be a widespread (or at least widely known) problem.
Just tried to PM you but I don't have enough posts!! PM me your email and I'll respond.
albert@velosdesignwerks
American Muscle Vendor Classifieds
09-09-2015 04:21 PM
Other British Cars
09-09-2015 04:18 PM
09-09-2015 04:17 PM
