Boost leak DTC P2281 help?
Old Apr 10, 2010 | 02:13 PM
Reborn996's Avatar
Reborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to behold
Question Boost leak DTC P2281 help?
Okay, it seems I have a boost leak after putting in the new diverter valves. At first I thought the install was messed up but I rechecked everything and it is good and tight. I also put in new sealing rings on the lower boost hoses to the intercooler as the drivers side one was removed for the install and was coated in oil. The o-ring did look a little worn but even after replacing it I still have the error code under high boost. My theory is that with the new EVOMSit software and diverter valves (the old valves would not hold full boost) once the engine saw the higher boost it developed a leak somewhere.
What is the best way to troubleshoot this? I checked the diagram for the boost hose system and it has an unbelievable amount of o-rings... would hate to have to take the whole thing apart to replace them all.
awesomebang
Jul 5, 2017 08:48 PM
Perkman87
Nov 19, 2015 05:31 PM
Jd1368
Oct 16, 2015 09:48 AM
Frank ( Sunnyside )
Bentley
Oct 3, 2015 11:13 PM
ECS Tuning - VW
Sep 25, 2015 02:22 PM
