Gutting secondary cats!
I searched and find it interesting that no one has simply gutted the secondary cats. I guess everyone would rather toss $700 at shiny parts.
The secondary cats simply unbolt and are at the end of the pipe for what looks like easy gutting.
I did this on my last Audi (500hp/600tq) and on my R1 and it works great. Takes a bit of labor but is free otherwise.
Anyone here actually done it on a Cayenne?
If I find some time I may dive into mine soon.
I thought they were $500. I got mine used for $300. Plus it saves 40lbs or so. I'll sell you my old cats for $300 and you can gut those and keep yours on while you spend a week getting mine cleaned out.
$580+ Shipping.
http://www.fabspeed.com/cayenne.html
Only took me about 2 hours do do the set on my Audi.
Yeah, I remember the post on it. I've thought about doing that too.
These cats look stupid easy to gut. Looks like you can just cut right thought the weld on the cat about 90% around so that it will open up. The cat material should just push out ofter that. Then closet it back up and weld it shut.
You could probably just smash the stuff out without opening it up too. That would take somem more labor, but still not out of pocket money.
....and at this point an advantage to gutting the factory set up until you get those out.
For what motors/trims?
I gutted the cats on my supra TT, but I would hate to bust out the cats and have something else go wrong and Porsche come back and blame them as the culprit for some other issue...then you are spending all that money you saved not buying pipes....
B. If no cats is going to effect some warranty part it will do it with a factory gutted cat exactly the same way nit would with fancy straight pipes.
C. I don't have a warranty. So the Porsche dealer will never see my car, ever.
I've seen studies over the years that gutting cats generally doesn't do much of an improvement over a straight pipe due to the fact the velocity of the gas flow gets disrupted so much - basically making a big turbulence box. I won't say it doesn't make a little more power than having the ceramic matrix in there, but there's more to be had if you keep the piping "smooth". Naturally most of the old magazines that showed this stuff were thrown away a long time ago (from back in the 1980s).
