>>> Carbon Fibered my Cayennes Dash Pod - Lots O' Pics of the process <<<<
#61
+1 on the CF. Aerospace composites has a lot of different material. I use a lot of those same teqniques on my rc planes. How does the glue work when you lay down the CF weave? Is it "wet" and able to be repositioned? I always use 3m-77 spray contact adhesive when skinning foam cores. Its strong but able to be repositioned, and it makes wrapping the compound curves easier. You could even brush the first coat of resin kinda lightly just to seal the weave, then spray the remaining coats. It would build alot more evenly and save a lot of sanding! Have you thought about vacuum bagging?
#62
3m spray - i tried it but was warned by a few that it can loose its grip on flat surface skins. I also found that the spray dries tanish in color and can show through any gaps in the weave. When using the tinted resin, you can reposition if you go apply it earlier in the cure process (while it is just getting its tack). This is fine for flat surfaces but you def need the stickyness for curves.
concerning spraying the resin, have not thought of that as I assumed it was way to thick. I started using a new technique where I lay the 2-3rd coats of resin down thick and then hit it with the heat gun on high. The heat gun works miracles - the resin actuals releases every buble and smooths over quite nicely. With that, sanding has gon way down.
I am working on my center console piece now and will post pics soon.
concerning vacume bagging, I ran some real ghetto tests (zip lock and a vacume) and the results were good. i just have not had time to buy all the equipment needed to do it.
#63
The 3m can dry out and lose its stickiness, but it is only for the initial positioning. When the resin is applied it will soak thru the weave. You only need enuf 3m to provide tack until the resin is applied. Like a LIGHT fog! Its quite strong. There shouldn't be any gaps in the weave for the 3m to show through. If you stretch the weave enuf to make a gap your stretching too much! Be carefull with the heat gun, you can alter the cure and finished strength of the resin.
Are you using a polyester or epoxy resin? What's the working time? You can thin the epoxy resin with alchohol. The polyester is no thicker than a heavy primer. Gelcoat is sprayed!
#65
Sorry brother - I only get high on my own supply ! If in the future that changes I will let you know.
#66
Why i cant see the pictures that you posted? I like your work that youve done, but for some reason the pictures you added on the forum i cant see, only the ones you added with the links
#67
Basically Photobucket told everyone to pound sand and proceeded to break the Interwebz.
04-28-2022 12:38 AM
