starter motor
Old Aug 12, 2013 | 12:29 PM
chizzy1961's Avatar
chizzy1961 is infamous around these parts
starter motor
my 05 v8 4.5s needs a new starter motor i guess, as sometimes it will only crank on the second turn of the key- sometimes it stops turning over the engine mid crank- also seems very sluggish at starting- had the coolant pipe upgrade about 4 months ago- possable coolant has killed the starter- my question is this:- do i need to remove the new alloy coolant pipes to replace the starter motor
thanks guys
Old Aug 12, 2013 | 04:21 PM
JSavinoJr's Avatar
JSavinoJr has a spectacular aura aboutJSavinoJr has a spectacular aura aboutJSavinoJr has a spectacular aura about
I believe that the starter is under the coolant pipes. So i'm thinking yes,you will have to remove them to get to the starter.
Old Aug 12, 2013 | 05:45 PM
Antoni Ralchev's Avatar
Antoni Ralchev is infamous around these parts
Try new battery first.
My Q7 used to do that when the battery got weak.
Good luck
Old Aug 13, 2013 | 09:01 AM
XR4Tim's Avatar
XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !
The starter can be wiggled out without removing any of the pipes. It's a tight fit, but doable.
But like Antoni said, check your battery first.
Old Aug 13, 2013 | 09:49 AM
chizzy1961's Avatar
tnx guys- should have said i have a new battery fitted 1 month ago
looks like its starter or bad earth wiring
COBB Tuning
Jan 5, 2016 07:06 AM
airbusdrvr
Dec 27, 2015 07:43 PM
Perkman87
Nov 19, 2015 05:31 PM
alpha motoring
Oct 2, 2015 12:04 PM
