What's a good amount of Durametric lowering that keeps it comfortable?
Old Dec 22, 2013 | 03:52 AM
Kaizu's Avatar
Kaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud of
Really impressed with the Durametric lowering!
Did just 25mm all corners for my non-GTS model with 21" winter tires.
I must admit the ride suffered a bit more than I thought of here in crappy roads. So, does it make any difference if I raise it up a bit? How much?
I have race cars with low suspension and this is my winter daily so more comfort could be appreciated...but going back to stock just is not an option for a car freak
Old Dec 22, 2013 | 07:31 AM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
You just have to play with tire pressure and height. There are not only different ride preferences, but also different ride height/ tire pressure combinations. Everything you change will be a trade off somewhere else. Try different tire pressures at different ride heights, keep a record, and select the combination that works for your expected use. You will likely have different combinations when use changes- in town, highway trips, off road, snow, sunny dry..... The experimentation is part of the fun.
Old Dec 22, 2013 | 08:29 AM
Dennis C's Avatar
Once you find the right combination, make sure to get an alignment with the suspension set where you will drive the car most often. If you don't, then you'll go through tires very quickly.
COBB Tuning
Jan 1, 2025 09:02 AM
Weebs
Nov 29, 2018 08:20 AM
MDYUKI1016
Aug 24, 2015 04:40 PM
WheelB
American Muscle
Aug 24, 2015 08:42 AM
Weebs
Aug 21, 2015 06:35 PM
