Custom ECU tune
Old May 23, 2014 | 07:40 PM
Drk Knight's Avatar
Drk Knight is a jewel in the roughDrk Knight is a jewel in the roughDrk Knight is a jewel in the rough
Custom ECU tune
Has anyone here had their ecu tuned specifically for the setup of their car? I should hopefully be heading to the dyno in a couple months and want my ecu tuned specifically to my car to get the most out of it. I will have an intake, cat back exhaust, including bypass pipes, to magnaflow mufflers. All of the ecu tunes out there are universal so I figured I can get more power if its tuned to accommodate the mods to the car.
Old May 23, 2014 | 07:50 PM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Good question. I'm looking for a tune as well. Going to give VRTune a try probably. I'll post up my thoughts. I'm not going to do anything but the flash so I can see what gains can be realized with just a tune.
Old May 24, 2014 | 05:13 AM
CaliGTS's Avatar
CaliGTS is infamous around these parts
Ecu tunes
Hey two both of u, my fellow cayenne fam !! Lol. With all ur mods !! Which ever tune u get weather a custom or a flash one it will give u the torque & hp u are looking for !! But the real deal hollyfeild is when u get it dyno'd they will tweak it in all the right ways !! If u get out to Cali let me knw
Old May 24, 2014 | 08:15 AM
CALMOTION's Avatar
CALMOTION is just really niceCALMOTION is just really niceCALMOTION is just really niceCALMOTION is just really nice
Cali GTS
Where is Cali are you? What tuning have you done? Sound like your speaking from experience?
Old May 24, 2014 | 08:38 AM
Mr. Haney's Avatar
Mr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to behold
All the tunes whether custom, chipped, or flashed on a CTT are going to get you about 520 hp on 93 octane without meth injection. The limiting factor is the turbos. Not that they cannot produce more boost, just that they are way out their efficiency range. That in turn produces a LOT of heat in the intake. This is why meth injection and intercooler upgrades are the most effective with a tune.
Old May 26, 2014 | 02:27 PM
lupo.sk's Avatar
lupo.sk is infamous around these parts
I've got an 06 TTS with custom Stage 2 hybrid turbos from Scroll products with 63mm compressor wheels, 550cc injectors, EVOMS intake + ram air, EVOMS DVs, custom 3" exhaust w/o primary cats, custom metal IC piping and custom metal plenum and CO2 IC spray (not yet finished) with a fully custom tune done by a local guy. due to wastegate issues and a boost leak somewhere, I'm currently only at 600hp and 880nm (650lbft).
Old May 26, 2014 | 07:39 PM
Skigod9's Avatar
Skigod9 is infamous around these parts
So all of your mods only bumped you up 80hp, That doesn't seem right
Old May 26, 2014 | 08:30 PM
mtnrat's Avatar
mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !
I think he means rwhp not hp at the crankshaft.
Old May 26, 2014 | 08:31 PM
BamaScoot's Avatar
BamaScoot is infamous around these parts
Also he stated he has a boost leak. Depending on how bad it is that could easily explain the (relatively) low power level.
Old May 27, 2014 | 03:04 AM
lupo.sk's Avatar
that's crank hp right now. it was up to 680hp, but then one of the o-rings probably went and we had dial it back to 600hp. Initially we thought it was WG issue, but those tested out fine.
I needed the car already (that was back in December...) and never had a chance to sort out the boost leak issue. I will do it this summer. Hoping for around 750hp.
Old Jun 3, 2014 | 08:02 AM
CALMOTION's Avatar
ECU Tune
Does anyone know of a good shop that does this in Norhtern Cal. Thanks
Old Jun 3, 2014 | 11:55 PM
ultimatelurker's Avatar
ultimatelurker is infamous around these parts
Sharkwerks
PenguiN
Oct 26, 2018 07:23 AM
Superaudiofreak
Sep 4, 2015 03:22 PM
Sep 1, 2015 03:16 PM
albert@velosdesignwerks
BMW //M
Aug 22, 2015 07:17 PM
