Cheapest AUX setup for 995 PCM w/ CD changer
Old Mar 1, 2018 | 12:44 PM
CayenneDream's Avatar
CayenneDream is infamous around these parts
Simple and easy question, though likely not a simple and easy answer...
I'd like to have the most basic addition to my Cayenne - a AUX port to play music. Nothing more, nothing less. Where to begin?
Thanks in advance.
Old Mar 2, 2018 | 03:59 PM
I just ordered from Amazon - LAPower A2DP Bluetooth kit
For $148 I figured it's a start as many other kits were much more expensive (Dension 3 times more...). Any thoughts? I will post this project...
No affiliate with Amazon or selling anything, guess this forum does though...
On Amazon:
Amazon Amazon
Old Mar 8, 2018 | 07:31 PM
La Power arrived...
Where to begin? (Have 6 disc CD changer, amplifier).
Old Mar 10, 2018 | 11:52 AM
After researching different AUX/Bluetooth options, I got the unit working... Pretty simple!
Here is the wiring setup... As the diagram with the unit was very unclear.
Works with Bluetooth and AUX. The other downside is that when an AUX cable is attached your bluetooth doesn't work. In order to use the Bluetooth, you must disconbnect the AUX cable from unit. Not the worst. Aftr holding down buttons '1-4-8' on the key pad to reset the PCM, everything worked perfect.
PCM connections:
(L) Light out (routes to the (L) AUX unit)
(R) Light in (remains attached to clip)
AUX connections:
(L) connects to PCM (L) Light out
(R) connects to the removed (L) Light out cable
Constant 12v power @ PCM:
(+) Red w/ yellow stripe
(-) Brown wire
Porsche997.
Jul 12, 2023 06:52 AM
tropicatango
Aug 17, 2016 07:36 PM
Jroy08
Cayenne 955/957
Oct 28, 2011 08:20 PM
split
Oct 13, 2010 09:31 AM
2Brakus
Jun 8, 2007 04:47 PM
