955 CTT no power to driver front door
Old Oct 31, 2021 | 03:11 PM
ciaka's Avatar
Wonder if anyone can recommend course of action or area to focus on.
I was repairing the front door actuator, replaced it..
after replacement and putting everything together,, the door does not have power.. the switches don't illuminate,, can't open close windows or lock doors with them,, the alar. Light does not blink when armed.. clearly power issue.. replugged, no luck.
Could it be that I have to replace the power motor module? The black box that the 3 main cables connect to, whith also connects to the gears for power windows? Need help here thanks.
Old Nov 1, 2021 | 05:20 PM
ciaka's Avatar
Success. It was the flat gray connector with purple cam. I needed to make sure cam is all the way to the back before plugging in, then after cam moved forward that the connection clicks well. All working fine now.
rich9911
Bentley
Apr 10, 2020 08:38 AM
Denver V8V
Oct 9, 2017 03:37 PM
Robotpedlr
Cayenne 958
May 21, 2016 09:22 PM
cinellipro
Apr 29, 2015 02:06 PM
brumma
Jan 27, 2012 01:20 PM
