Install a PCM 3.1 on Cayenne Diesel With CDR 31
Old Dec 17, 2013 | 08:55 PM
  #31
TGED's Avatar
TGED is infamous around these parts
FM radio station frequencies in North America end with an odd digit, eg. 98.1 98.2, in some Asian countries, it ends with an even digit, eg. 98.0 98.2
I remember some of the all regions home use FM digital tuners have a switch to adjust this, because the frequency goes up/down by 0.2MHz, so you need to set the tuner to start from an even or odd end frequency. Hope I am not confusing you.
Old Dec 17, 2013 | 11:07 PM
  #32
G_A's Avatar
G_A
G_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of light
Confusing Me?)))
Switch freq. step not necessary on European headunits, they can receive odd and even stations because step = 0,1MHz.
But then you put head in the car, you will need perform coding with piwis tester.
After this you will see NA frequency step.
Old Dec 18, 2013 | 07:24 AM
  #33
TGED's Avatar
My Canadian PCM head unit does have 0.2MHz increment. So there is regional difference.
Old Dec 18, 2013 | 07:31 AM
  #34
VL_599's Avatar
VL_599 is infamous around these parts
I see, I did not know that. So there is differences.
Old Dec 18, 2013 | 07:33 AM
  #35
VL_599's Avatar
Originally Posted by G_A
Confusing Me?)))
I see, it is strange...
So there are no serious problems related to the FM receipt
it can work in Europe.
How do you think about this unit?
they said - fully tested.
http://www.ebay.com/itm/11-12-Porsch...5e5b50&vxp=mtr
Old Dec 18, 2013 | 07:49 AM
  #36
G_A's Avatar
G_A
as I see
"11 12 Porsche CAYENNE Navigation Radio Satellite XM Bluetooth CDR-31 Phone MP3"
They do not know what they sell
PCM or CDR.
NAVI CDR))) funny.
And expensive
Here i buy PCM3.1for 750-800 USD.
Old Dec 18, 2013 | 07:55 AM
  #37
VL_599's Avatar
as I see
PCM or CDR.
NAVI CDR))) funny.
And expensive
haha, cdr with navi and xm,
If you hear that someone selling let me know.
Old Dec 22, 2013 | 02:19 PM
  #38
VL_599's Avatar
Finally after a long search I ordered PCM 3.1 for my Cayenne.
It is from Uk car, Cayenne PCm 3.1 (Europe version)
manufactured in october 2012. Cost me 600 GBP with shipping.
I'm in the game
One question about gps antenna.
On ebay I found original gps antenna for cayenne 958.
where is this antena located on car?
http://www.ebay.com/itm/Porsche-958-...item257b1d9dad
as you suggested I found fakra gps antenna on ebay, price 7 eur.
http://www.ebay.de/itm/GPS-antenna-F...item25867c1bfa
my car is without heated windshield, so we shoud put it somewhere under dashboard.
About operating instructions WKD 952 020 13 → English
do you have some document about this? procedure?
There are still a lot of work in relation to the conversion, I bought the PCM))
Thanks for help.
Old Dec 23, 2013 | 02:23 AM
  #39
G_A's Avatar
G_A
GPS located under cover on top of the windshield - in EU car. As I see americans - they has kind of antenna on roof in rear part. You found non EU gps on ebay.
My suggestion - try 7$ fakra. put it on roof and then under dash, to compare GPS reception, go to "position info" in pcm menu to see how many sats in use.
I do not have manual in English.
Do you have amp and wires?
Old Dec 23, 2013 | 02:54 AM
  #40
VL_599's Avatar
Ok, I will order fakra today,
I'll tell technicians from Porsche to do like that. pcm will arrive in 10 days.
The next step is amp and wires.
I think I'll order this week. I have your list with codes and part names.
part 958.645.302.00 Amplifier price is 400 eur. I didn't check prices for wires and other, I hope it is not expensive)
So all parts from your list are ok for cdr31 to pcm 3.1 conversion? I can order them?
I asked you about operating instructions WKD 952 020 13 → English,
this is official procedure from Porsche? wiring diagram for new amp and cables is there also?
Porsche deler will install this but I wanted to have this also in any case.
thanks
Parts
958.645.302.00 1 x Amplifier
958.645.225.00 1 x Holder
N .910.967.01 5 x Hexagon-head bolt, M6 x 16
958.612.530.00 1 x Fuse holder
958.612.090.20 1 x Wire harness (battery to power distributor)
955.044.902.44 1 x Connector module C (coding: blue)
999.607.073.00 1 x 40 A fuse
999.513.076.40 20 x Hose clamp
958.612.838.00 1 x Tie-wrap with retainer
999.652.570.22 8 x Pin contact
955.044.902.23 1 x PCM/amplifier wire harness
958.044.900.17 1 x Amplifier/PCM wire harness and additional connector housing
N .911.475.02 8 x Combination screw for seat, M10 x 35
N .989.520.01 1 x Screw (M11.113 x 1.27 x 18), rear belt[/SIZE][/SIZE][/SIZE]
Old Dec 23, 2013 | 03:18 AM
  #41
G_A's Avatar
G_A
itake part list from conversion manual.
But if you would like save some money - look on i-sotec 4amp with quadlock cable adapter
WKD 952 020 13 → English is just owner manual, no installation tips, no wirings)
Old Dec 23, 2013 | 04:26 AM
  #42
VL_599's Avatar
I see, my mistake Porsche dealer have this conversion manual?
Is it easy to connect pcm with new amp and all cables?
But if buy i-soctec amp and quadlock I'm not sure that Porsche will accept to install. Car is still in warranty. Just a guess.
Also I will need codes to activate navi, offroad navi, bluetooth and usb.
(I allready have bluetooth on my cdr31) pls help
Old Dec 23, 2013 | 06:24 AM
  #43
G_A's Avatar
G_A
Dealer of course have all manuals.
Installation of I-sotec amp will be aesy, but in you case may be better follow original way.
To keep all in original.
Will you replace antenna amp and wiring?
Regarding codes - see PM
Old Dec 23, 2013 | 07:23 AM
  #44
VL_599's Avatar
You mean radio Fm antena? do I need to change this?
Is it the same antenna connector from Cdr31?
radio cable connector wiring on cdr31 is the same as on pcm 3.1 ?
Old Dec 23, 2013 | 07:36 AM
  #45
G_A's Avatar
G_A
no.
You should change connector housing.
use 970.044.900.99
or universal coding blue housing.
According manual you have to change antenna amplifier, 958.647.312.01
But this will not improve FM reception imo.
