958 CTT Fabspeed Cat Bypass pipe install - success!
Just installed the cat bypass and thanks to the tips here it went pretty smoothly.
Ran into an issue installing the mufflers since I was under the impression the fabspeed simply bolts on but looks like I need to cut the OEM piping which I'm not too comfortable doing... Anyone done a muffler swap? Any tips?
almost every aftermarket exhaust requires cutting/sawzall to change the mufflers. most all are usually the slip on style with clamp. the only exhaust that doesn't require cutting for the cayenne is probably akropovic. I had access to a lift when I installed my mufflers, laying on your back with jack stands would probably be a pain in the ***. any muffler or tuner shop should be able to install them for you.
I'm interested in your Fabspeed muffler install since i'm tempted to take that install on too.
I'm also interested in your review of what the Fabspeed muffler and bypass pipe combo sounds like.
So finally was able to do the exhaust after running into some fitment issues with the piping not fitting over the oem piping... Had to loosen the oem pipes (the ones that go In between the muffler and sec cats) so everything could line up easier.
Overall impression... Its okkkk. I'm more use to louder systems that's all. Came from a few 997 Tt with catless system so take it for what it is. I think the majority of members would be happy with it I just wanted something louder. I was able to hear the CTT with no mufflers hooked up and to be honest would have drove it like that if I could
With the mufflers now its probably a 6-7 of oem is a 2-3 and oem w/ cat delete a 5.
Do you still have the secondary catalytic converter pipes in place or did they remove them (Secondary Cat bypass)?
It's strange that i often find myself turning down the stereo to listen to the sound of the motor/exhaust instead.
I'm actually considering the Fabspeed Maxflo Sport Performance exhaust system next.
I love the sound of both cars and rarely play my stereo for this very reason, so I totally get it! You should def do the full system on your CTT. I'm just sticking with the Bypass pipes on the GTS, since this is the wife's car. Can't wait to see the pictures, videos and your review, once you install it and have the car adapt to it.
Yes, i still have the secondary cat converter i just replaced the muffler with fox muffler
