Air-con draft issue!
Hi Guys,
In the past few days, I have observed that the draft from the Air-con system on my 958.1 S isn’t fine.
It’s a RHD car and the right most (Driver’s side - near the window) has minimum draft even if the fan setting is on full.
Also, when the Air-con is on, the draft on the front passenger side footwell gives out draft as if its with the Aircon off.
Hoping a cayenne specialist on this forum might be able to help :-)
Have you replaced the cabin air filter recently or adjusted it?
There is a plastic pipe that must be seated and directs airflow between the blower motor and cabin air filter. If the pipe isn't installed correctly then the blower motor will just be blowing air directly into the footwell.
Check that out and feed back
I just did the cabin air filter swap today and can confirm this issue as well. My pipe was dislodged from the clamp. After replacing the filter and resetting the clamp from the plastic pipe in the correct location all is well. Man those cabin filters get filthy!!!
