Cayenne S Hybrid 2012 "Fault Hybrid Fault" Yellow error
Old Jul 12, 2017 | 03:23 PM
healthyspeed's Avatar
healthyspeed is infamous around these parts
Hi everyone,
I have a 2012 Cayenne S Hybrid with less than 12,000 miles on it. However when I drive the vehicle hard for about 15min, a warning sign in yellow shows up on the dash "Fault Hybrid System". The car continues to run without the battery assist and the fault disappears after a cooling down period, mostly after restarting the vehicle after some minutes.
Anyone experience this? what is the resolution?
Old Oct 5, 2017 | 03:55 PM
Gregg Baum's Avatar
Gregg Baum is infamous around these parts
Unhappy I feel your Angst
Dealing with this right now on my '11 Cayenne S Hybrid. I get the yellow Fuel Cap warning as well. When the red Hybrid Fault warning goes off, I am restricted to 2nd gear, 2000 rpms until putting her in park and shutting engine off. Then she restarts fine - no warning light - and away she goes. Weird, Ghost in the Machine type ****...
So far the Hybrid Fault isn't showing up in the code registry upon service check...
Old Oct 9, 2017 | 02:05 PM
Sent my cayenne to the dealership, which is about 500km away
Luckily they were able to reset the codes. No problems so far. Pushing the vehicle hard and hybrid system seems to operate well, even during hot climate (35C celsius). Have activated extended warranty now
Best solution is to take it to the dealer. Take some pictures of the fault.
Old May 16, 2021 | 04:37 PM
Saleh Fahad's Avatar
Saleh Fahad is infamous around these parts
Originally Posted by healthyspeed
Hi everyone,
hello
i got same issue in my car hybrid 2013 cayenne
did you find any solution?
fault code is
p0a0a00
p0aa600
Old Sep 14, 2023 | 12:38 PM
stphnsns's Avatar
stphnsns is infamous around these parts
Hi, did you ever figure this out? I'm experiencing the same. 2012 958 Hybrid with 86k miles.
Thank you!
Originally Posted by Saleh Fahad
hello
fault code is
p0a0a00
p0aa600
milspecpanda
Cayenne 958
18
Apr 21, 2022 09:27 PM
JDSMiami
Cayenne
Jul 12, 2017 12:05 PM
hotcello
Cayenne 958
Mar 13, 2014 10:14 PM
TechWizard
Cayenne 958
Nov 16, 2011 02:10 PM
