Headlight Gaskets for 2011-2014 958
Old 03-07-2018, 02:18 PM
jayi836's Avatar
jayi836 will become famous soon enoughjayi836 will become famous soon enough
Anyone seen a DIY for making replacement headlight gaskets?
mine are brittle and gooey to the touch.
Replaced my horns this past weekend and noticed what a sad shape they were in.
Dealer says not available for this model, but available for the 2015 and up models. or the 955's
Old 03-19-2018, 09:26 PM
Macporsche015's Avatar
Macporsche015 is on a distinguished road
in Porsche's ultimate boner decisions, this gasket can not be replaced, it is part of the HL assy......... so my fix was these headlight rings to cover up the matreial ............
ID:	522629   Click image for larger version
Old 03-20-2018, 08:01 AM
jayi836's Avatar
Nice work, I didn't even know that was available.
I have a few "High-Temperature Hollow Rubber Flange-Mount Seals" picked up from Mc Master-Carr.
Will attempt a repair in the next few weeks looking for something to bond the old frame to the new rubber seals, thoughts?
3M™ Scotch-Weld™ Plastic & Rubber Instant Adhesive or 3M Super Weatherstrip Adhesive.
Old 03-20-2018, 04:27 PM
deilenberger's Avatar
deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !
Where are the trim rings available from?
Old 03-20-2018, 09:44 PM
Head light bezel
I found the on EBay Motors
Old 03-20-2018, 09:45 PM
https://www.ebay.com/itm/Porsche-Cayenne-2011-2012-2013-2014-Headlight-Chrome-Trim-Set-2-pcs/172961729122?hash=item2845528a62:g:Vh0AAOSwdSRZ-98F&vxp=mtr
Old 03-21-2018, 10:32 AM
Thanks. Can we see a picture of them installed on your P!G? TIA!
And - how do they attach?
Old 04-03-2018, 11:41 AM
i had them wrapped when I Blacked out the rest of the car, the are attached with a super sticky two sided tape............ my one beef is the still do not cover the black gasket material completly. Might need to run a bead around them, I was looking at the 3M sealant used to install windsheilds, should have the UV properties needed. Pictures attached.
Old 04-05-2018, 08:41 AM
Bummer that they don't cover the rubber. My rubber gaskets look OK - but I think I'm going to R&R the headlights and give them a silicone grease treatment..
Old 04-09-2018, 01:30 PM
RAudi Driver's Avatar
RAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud of
Hang tight guys. I have rolls of light gray butyl. This is the original stuff used to seal headlights for most manufacturers.
I don't know what Porsche uses and mine might not be the same, assuming they are using rubber gaskets. However, it would probably work in place of the rubber gaskets and provides a perfect lifelong seal for the headlights. You can also trim the areas that it will squeeze from the headlights and it should look perfect.
I'll toss up a few pics later this afternoon asset rI get back from a meeting and picking up my son from school
Old 04-10-2018, 08:55 AM
KKTurbo's Avatar
KKTurbo is an unknown quantity at this point
Macporsche015, how secure do the rings feel? Can the rings withstand the wind when driving 100+ mph? Not that I drive that fast...(crossed fingers behind my back). I would hate to have one fly off and hit the windshield or someone behind me. Looks great though!
Old 04-10-2018, 09:16 AM
Elberoth's Avatar
Elberoth is an unknown quantity at this point
I wonder if Porsche will start offering the gaskets when more ppl start reporting the problem. Replacing the complete headlights assys is not a solution.
Old 04-16-2018, 10:44 AM
jayi836's Avatar
I had some time to test fit the sample gaskets I ordered. Color a bit off
These were 1/4", I ordered some 3/16"
McMaster-Carr, High-Temperature Hollow Rubber Flange-Mount Seals, Temp range -100°-480° PN#1129A978
These bulge a bit on the top
east fit with a hole punch no adheasive
What great quality
Old 04-16-2018, 10:50 AM
jayi836's Avatar
New part on order, Water- and Weather-Resistant Hollow Rubber Flange-Mount Seals Temp range -20°-200° PN.1142A37 ,A bit concerned with the temp range.
I prefer the 480° version but not available in this size.
Old 04-16-2018, 06:35 PM
Jay - these look like a much-needed alternative to the not available part from Porsche.. can't wait to hear which one looks/fits the best. If these are made of Viton - use of some silicone grease - worked into the rubber - will help protect them from your California sunshine and ozone. We don't have that problem in NJ - we just have humidity and rain. Lots of humidity and rain so far this spring.
Quick Reply: Headlight Gaskets for 2011-2014 958
