White smoke، engine oil burning and p0308 misfire
Old 03-17-2019, 09:23 PM
slc.zak3's Avatar
slc.zak3 is an unknown quantity at this point
Do anyone can help with my case
- very strong white smoke in exhaust with a bad smell (worse in city center diving with traffict jammed and it's less in highways)
- oil reach to spark plug no 8 only, all others are fine.. then getting p0308 misfire most of time.
- oil loose as it's burning .. approximately 1 liter every 400 km in city .... Or 1 liter every 1500 in highway
Do any face the same .. I meed your help please
Old 03-18-2019, 09:13 PM
Jay Vong's Avatar
Jay Vong is an unknown quantity at this point
Check to make sure you don’t have a scored cylinder walls. It’s looking like it. Do a compression test. Easiest way to tell. Then a boroscope.
Is there a lot of oil around the spark plug? Could be the plug seal. Worst case engine is toast
Old 03-19-2019, 06:42 PM
slc.zak3's Avatar
Thanks Jay,
cylinder walls is fine,
I had replace spark plug 3 times and still the same.
regards to engine, as per my experience, it should in different cylinders and oil burning and exhause smokes become more in highways....
Old 03-24-2019, 08:49 PM
slc.zak3's Avatar
Can you guys make any suggestions or give any advice?
Sweet35th
Cayenne 958
10
10-04-2017 07:19 PM
spmorgan
12-08-2014 06:13 PM
caunyd
12-09-2011 03:58 PM
caunyd
12-04-2011 01:44 PM
hramos
10-05-2011 06:24 PM
Quick Reply: White smoke، engine oil burning and p0308 misfire
