Rear powerboot retrofit
Hello!
this is a function that I miss a lot in my car. I understand it to be an easy retrofit with a couple of power lifts, module, harness and some programming. Maybe someone could help me with parts and wiring? thanks a lot. |
Hi - where did you see that it would be an easy retrofit? On German cars there is rarely an easy retrofit since the wiring harnesses are bespoke - made for what the car is equipped with when it leaves the factory. Just curious if anyone has done this - since to me - it would seem a somewhat daunting project (and I once added ABS to a motorcycle that wasn't equipped with it from the factory - that was a huge project..)
