Bone Stock Cayenne Turbo 1/4 mile Time
Just got back from taking my bone stock 2005 Cayenne Turbo to the drag strip. All runs were at 600ft (approx) above sea level and it was around 90-91 degrees outside. The best time I could do was a 14.402 at 99.25, reaction time was .289 and 60ft was 2.453. All of my runs were with PSM turned off, sport mode enabled, and transmission in auto (not tiptronic). I kept getting better with each run and after the 4th run we decided to let the car cool down for a 1/2 hour thinking it was probably heat soaked. By the time the 1/2 hour had pass a rain storm moved in and they shut the track down. Bummer!
Anyone else have a time slip of a stock Cayenne Turbo? I'm thinking a tune is a must now.
Thanks. I wanted to get a baseline before my FVD tune came in to see how much of an improvement it would be. I will be throwing the car on the dyno to get a before and after. I'm hopeing this tune will get me into the 13's, we will see!
What did you end up with on the dyno running it stock?
Dan87951, can you please share your feedback on the FVD tune? Did you dyno results align with their graphs?
What about your drag strip times with the FVD tune?
How is drivability, anything else better or improved other than power?
Im trying to decide Softronic or FVD, any thoughts would help!
