Trouble Code P2181
Old Feb 6, 2013 | 02:00 PM
bradleycorr's Avatar
bradleycorr is infamous around these parts
Trouble Code P2181
Does anyone have a code description for fault P2181.
Thanks,
Brad
Old Feb 6, 2013 | 06:04 PM
porschespeeddemon's Avatar
porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !
Thermostat stuck open, likely will require replacement of the thermostat housing and thermostat. Good time to replace the (most likely) plastic pipe in there as well.
Old Feb 6, 2013 | 06:46 PM
Thanks for your quick response, and may you have a wonderful day..-b
Old Feb 6, 2013 | 07:00 PM
Likewise.
PS there is a TSB on specified fault code, when applied to 2008/09 V8 Cayennes.
Old May 2, 2013 | 03:32 PM
the don's Avatar
the don is infamous around these parts
Where can I find that TSB? Code just popped up on mine but no overheating yet.
Old May 2, 2013 | 06:52 PM
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
A stuck "open" thermostat would not cause overheating. It would actually "over cool" the engine and not allow it to get to warm up temps. A stuck "close" thermostat would cause overheating in a very short period.
Old May 3, 2013 | 03:36 PM
the don's Avatar
So it's either or? I guess that would mean that mine is stuck open. I spoke to the Porsche dealer and they said that its a good time to replace the internal plastic cooling pipes as well. The new ones are metal and should last forever. The whole thermostat and housing with seals and gaskets with the cooling pipes runs about $1,300 in parts alone. But considering the price of one of these engines it's well worth the maintenance cost.
Old Nov 10, 2013 | 03:38 PM
rugaspen's Avatar
rugaspen is infamous around these parts
Why do both thermostat & housing ?
Why does the failure of the thermostat also require the replacement of the housing?
I have an extended warranty that specifically excludes thermostats and in the fine print if the failure of a non-covered part (thermostat) causes the failure of a covered part (housing) neither is covered by the warranty.
Prestige Audi/Porsche in Denver have been very helpful but the warranty company is playing hard ball.
If the housing needs to be replaced unrelated to the stuck open thermostat I think it should be covered saving me big $$$
If anyone can explain why the housing needs to be replaced as well I would love to know.
Old Nov 4, 2014 | 06:51 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
1st thermostat replaced at 60k ish
thermostat stuck open again at 104k. Replaced again along with new water pump just because of miles. Updated thermostat is on 4th revision
My shops done a little over 20 957's past couple year
Old Nov 5, 2014 | 11:49 AM
Moderator
I do not buy that the housing has to be replaced as well. I did mine without the housing at over 25K miles ago and have had no issues. My guess is that the housing may get damaged in the thermostat socket removal, so they just replace it proactively; regardless of whether it needs it or not.
Old Nov 5, 2014 | 12:25 PM
90sundevil's Avatar
90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of
There is a class action lawsuit over the plastic coolant pipes and people who replaced them get compensation.
Old Nov 5, 2014 | 05:00 PM
geetee's Avatar
bingo. non trained shops can damage housing when removing due to location of thermostat
intouch1
Sep 20, 2015 06:14 AM
kkswow12
964
Sep 11, 2015 10:31 PM
Yogi911
Sep 9, 2015 08:20 PM
